Ninja leaking petrol from the overflow!!
number_two
PostPosted: 22:00 - 09 Jan 2011    Post subject: Ninja leaking petrol from the overflow!! Reply with quote
Hey everyone.
This might be a simple fix, i hope so.
I flushed my fuel system out with some of that Redex and ever since the overflow pipe has leaked/dripped constantly. I guess that the Redex has eaten into the joint somewhere/chewed through the rust if its rusted somewhere.
Ive now cut and plugged the pipe but still have an eggcup full of petrol laying in the pipe inside the tank and the short rubber hose ive left attached so i can plug it.
Any ideas on how to permantly repair this? Anyone else had this problem and how did you solve it?
I was wondering if there was an epoxy resin type product(not sure if epoxy is petrol proof) that i could pour into the overflow to re-seal the pipe from inside. The other idea was to fill it completely with something and loose the overflow all together. And my last thought was to reinstate the petrol overflow pipe but attach a tap at the bottom that i could open if needed.
Any help appreciated
No.2
craigT19
Jolly Green Giant
PostPosted: 22:02 - 09 Jan 2011    Post subject: Reply with quote
what overflow? do you mean the float bowl overflow on the carbs?
Bikes owned :- 2001 nsr125, 1999 zx6r, 2006 yzf-r1, 2009 xmax 250, 2012 yzf-r1, 2015 MT-07
Current bike : - 2016 MT-10
Crying or Very sad BCF member pops. sadly missed Crying or Very sad 1945-2003
hornetmike
PostPosted: 22:05 - 09 Jan 2011    Post subject: Reply with quote
I am not expert but I had that same problem is it overflow on carbs ? if so then pluging the hole makes it worse cause now the fuel will be leaking through the jets into airbox and into the cyclinder. Smell your oil see if it smells of fuel.
try tapping the carb floats, if that doesn;t work carbs will have to come off and check flout valves will need to be checked
87 Honda CG 125 - 97 ER5 - SR 50 -81 Z250- 96 CBR 600 F- 94 GPX600R 88- GPX 400R- 87 GS 125 - 2006 Honda CB600F- 2003 ER5 - Honda CBF 1000 2009 - Honda CBR 600 RR 2011
Current BMW R1200GS 2010
craigT19
Jolly Green Giant
PostPosted: 22:08 - 09 Jan 2011    Post subject: Reply with quote
If it is the carbs as said above strip them if u left a fuel/redex mix in the float bowls chances are the redex has fuxked your needle valves, those ar normally brass with a rubber tip and the redex can eat the rubber causeing the carbs to flood constantly.
number_two
PostPosted: 22:12 - 09 Jan 2011    Post subject: Reply with quote
Oh no. D'OH, apologies for missing that nugget of info, the carbs are fine, Redex actually made them better. Its the petrol tank overflow. It has a pipe that runs internally from the ring next to the fuel cap to the base of the tank.
craigT19
Jolly Green Giant
PostPosted: 23:45 - 09 Jan 2011    Post subject: Reply with quote
oh right erm short of getting a new tank you could always just plug the pipe?
ZRX61
Victor Meldrew
PostPosted: 04:52 - 11 Jan 2011    Post subject: Reply with quote
Plug the end of it... or buy a new tank..
They're not one night stands, they're auditions.
finpos
PostPosted: 19:27 - 11 Jan 2011    Post subject: Reply with quote
That's the water drain. Requires very much a can-do attitude to fix (you need to cut the old one out, braise a new one in and paint the resulting mess) and if it's blocked your bike will eventually conk out in the rain.
Lot of work / new tank / do not go out in the wet or wash bike!
f.
number_two
PostPosted: 22:15 - 12 Jan 2011    Post subject: Reply with quote
Consider it plugged, all other options dont appeal and im not really any good at brasing anymore. I'll keep an eye out for a cheap replacement tank in the meantime.
Thanks for the replies and opinions
No.2
ZRX61
Victor Meldrew
PostPosted: 02:43 - 13 Jan 2011    Post subject: Reply with quote
Mine's been plugged for 9 years...
nowhere.elysium
The Pork Lord
PostPosted: 16:15 - 13 Jan 2011    Post subject: Reply with quote
Yeah, but the rain in England is a bit more constant than in USland...
The last post was made 15 years, 307 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.09 - MySQL Queries: 13 - Page Size: 69.79 Kb
