Anybody Homebrew?
Benson_JV
PostPosted: 19:07 - 12 Jan 2011    Post subject: Anybody Homebrew? Reply with quote
Just wondering if anyone here Homebrews.
I do all-grain homebrewing. Much cheaper than the shops and tastes better to boot! Laughing
Charlie
PostPosted: 19:20 - 12 Jan 2011    Post subject: Reply with quote
I got a kit from my girlfriend, I've got 40 pints of Youngs Bitter in a drinkable state at the moment. It was my first one and I am impressed with it. This is going to be my next brew, Christmas present off girlfriend's parents.
pepperami
PostPosted: 19:48 - 12 Jan 2011    Post subject: Reply with quote
Got a 40 pint kit as a Christmas present, I hav`nt got a clue and the instuctions are very sparse Sad
where the hell am I going to get 40 resealable pint bottles Confused
Benson_JV
PostPosted: 19:50 - 12 Jan 2011    Post subject: Reply with quote
Looks Ace charlie!
Pepperami: When I bottle brews I just use 2L and 1L pop bottles. Makes no difference to the taste and it saves sterilising and rinsing 40 bottes!
Do you have the fermenting bin? And all of the other ancillaries?
LordShaftesbu...
PostPosted: 20:03 - 12 Jan 2011    Post subject: Reply with quote
Perfect excuse to drink 40 bottles of Grolsch!
pepperami
PostPosted: 20:08 - 12 Jan 2011    Post subject: Reply with quote
Two big tins of gloop, a small packet of yeast?, and some instrutions that fit on the back of a postage stamp Smile .
Now I know that I can use 2L pop bottles, that will help Thumbs Up .
fermenting bin?????? Confused thats a big plastic bin right?? 40 pints !
Ancillaries???? sounds like a type of antibiotic Smile
pepperami
PostPosted: 20:11 - 12 Jan 2011    Post subject: Reply with quote
40 bottles of Grolsh, Hmmmmm (salivates like Homer simpson)
Poseidon
PostPosted: 20:12 - 12 Jan 2011    Post subject: Re: Anybody Homebrew? Reply with quote
I mostly do wines now. Did a few beer kits, was impressed by them (especially the brupaks ones). I've got some plum wine conditioning as we speak... I left the skins in a bit too long so it may be a year or two before it's mellow enough to drink, but as the plums came from trees found near my house, it cost me all of £1.30 to make 12 bottles worth. I made a cracking sparkling peach wine last year and I tried making hawthorne wine, but that didn't end well.
I was very tempted to go all grain, even looked at making my own mash tun and boiler using a cool box, copper pipes, large bucket and elements from kettles... However moving house has put that on the back burner for a while.
1977 Honda CG125
pepperami
PostPosted: 20:22 - 12 Jan 2011    Post subject: Re: Anybody Homebrew? Reply with quote
You dont live in the isolated backwoods and play the banjo by any chance Laughing .
on a serious note, around here in the Autum, there is shed-loads of fruit going begging in the hedgerows.
nobody picks it except me Surprised .
I hav`nt made any wine, but I have made blackberry jelly and apple pies.
I dont know what to do with the plums, but I bet they would make good wine.
Benson_JV
PostPosted: 20:58 - 12 Jan 2011    Post subject: Reply with quote
Pepperarmi, I wrote up a rough how-to and I've listed the items you'll need to start.
https://www.hopandgrape.co.uk/catalog/detailV2_8.asp?itemid=SEV20114945&catid=FER374247
https://www.hopandgrape.co.uk/catalog/detailV2_8.asp?itemid=WOO20195952&catid=GEN2150855
https://www.hopandgrape.co.uk/catalog/detailV2_8.asp?itemid=HYD20183229&catid=TES20124240
https://www.hopandgrape.co.uk/catalog/detailV2_8.asp?itemid=TEL20182646&catid=TES20124064
IGNORE anything about putting sugar in the fermenting bin in this, I should've read that you had a 3KG brew kit which does not need additional sugar, but I'll leave it in the how-to incase you want to do a 1KG kit
You also need to buy 'Miltons Baby Sterilising fluid'
As before you do anything you need to sterilise all equipment being used for half an hour. After this time you need to throughout flush all equipment out with clean water (if not done it will result in infected beer)
After this has been done you need to open the can of beer and place all liquid (goop) in the Fermenting barrel then using boiling water, remove all goop from inside the can (just fill it up and using the spoon wipe down all the goop inside) this all needs to go into the fermenting barrel along with 1KG sugar.
Fill up about 5 litres of boiling water in the fermenting barrel and make sure ALL goop and sugar are dissolved then fill up to 23L (40 pints) with cold water, at this point put the HYDROMETER (glass stick) in and read the number on it (should be roughly 1040 for this kit) And record this number to later on see how strong your brew is.
At this point you need to put the supplied sachet of yeast into the brew, put the lid on and put it somewhere between 18-22C for a week or so.
Do not be tempted to remove the lid too often, once a day to see how the brew is going is okay, so that you can record how it looks from day to day.
It will foam and look pretty nasty on top of the beer, this is perfectly normal. Once the foam and shit has died down, take a reading with the HYDROMETER and record the number, and do the same the next day, if the number is the same (should be under 1020, if it is not then sanatise with the miltons the brewing spoon and give it a good stir) you are then ready to bottle! Just make sure the reading is the same over the two days.
BOTTLING:
I use pop bottles. Coke, or fanta etc. Just make sure they PREVIOUSLY held fizzy drink else you may choose a wrong bottle and it'll blow.
You need enough bottles for 23L so you can use 23L 1L bottles or enough 2L and 1L to make 23L I tend to use about 8 2L bottles and the rest 1L.
Sterilise the bottles as per the brewing equipment by using the miltons for half an hour (remember to use the correct ratio of miltons to water) and make sure they are rinsed several times. Also make sure to sterilise the syphon tubing.
Once each bottle is sterilised and emptied you need to add sugar (so that the brew carbonates) for a Lager I generally use 1 and a half TEASPOONS of sugar per 1L bottle and for everything else I use 1 teaspoon per L
Then using the syphon (which has been sterilised and rinsed remember) syphon the beer into the bottles and put the tops back on.
Make sure you shake the shit out of the bottles to dissolve the sugar into the beer. Then leave the bottles in the warm for about a week and then leave them outside for at least a week before attempting to drink any. The longer you leave them the nicer they'll be.
You can start drinking them after about a week after being outside, but I would suggest leaving them for about 3-4 weeks.
Hope this helps dude.
Let me know if you have any problems.
Poseidon: It is very much worth going all-grain! Tastes so much better than kits! Do it asap!
pepperami
PostPosted: 21:01 - 12 Jan 2011    Post subject: Reply with quote
Very much thank you Mr Benson Thumbs Up
Benson_JV
PostPosted: 21:03 - 12 Jan 2011    Post subject: Reply with quote
BOTTLING:
Jesus I tried to edit my post and I bloody quoted it!
Benson_JV
PostPosted: 21:07 - 12 Jan 2011    Post subject: Reply with quote
You're most welcome. Any other info you need just let me know!
Willson
PostPosted: 21:10 - 12 Jan 2011    Post subject: Reply with quote
Benson's Beer Goooooooood!
I think it's time for me to get another batch!
Benson: Wouldn't life be easier if we were all turtles?
Me: Pig on bread = The way forward.
Riding: '00 Suzuki SV650S. Previous: '99 Kawasaki ER5 - sold, '02 Suzuki GZ125 Marauder - sold
AngelGrinder
PostPosted: 21:47 - 12 Jan 2011    Post subject: Reply with quote
I have done 3 brews over the last 6 months, only one sucessfully. My first beer batch ended up sweet, the second batch, I bought some cheap plastic bottles off eBay and they lost pressure so ended up flat, but seemed to tase fine before that. My most recent batch...strawberry cider was drinkable, and now after a few months is really nice!
The only problem is the sugar not fully dissolving, so I can't take them anywhere. Would a keg solve this problem? I've tried using less sugar, to no avail, any tips?
hellkat
PostPosted: 21:57 - 12 Jan 2011    Post subject: Reply with quote
I got given a couple of demijohns over the summer.
So I picked some tiny plums when I was waiting round for something one day, and ended up filling one demijohn.
Possibly I might not have put enough sugar in.
Or maybe I didn't stir it.
Only another 3 months or so til I find out.
https://www.facebook.com/photo.php?fbid=441562189690&set=a.441561464690.238231.662609690#!/photo.php?fbid=441562194690&set=a.441561464690.238231.662609690&pid=4952190&id=662609690
hellkat
PostPosted: 21:58 - 12 Jan 2011    Post subject: Reply with quote
Arse.
Why didn't that work.
Mad Middle Finger
Benson_JV
PostPosted: 22:03 - 12 Jan 2011    Post subject: Reply with quote
1) It'd have been sweet because the yeast didn't eat all of the sugar for some reason and thus the gravity was too high. To combat this you need to double check the gravity readings and give it a stir.
2) Bum bottes unfortunately!
The sugar in the bottles? You just need to shake the living shit out of them when you bottle, it doesn't do them any harm!
HTH
Poseidon
PostPosted: 22:05 - 12 Jan 2011    Post subject: Reply with quote
Used to live in a valley with only a couple of other houses near by. I once was sat in a wooden chair in the garden sharpening an axe thinking how much I must've looked like the bad guy from a horror movie!
Plums are dead easy to make into wine. I mushed them down, added a bit of brewing sugar and some boiling water... Put a bit of pectolase in and left it for 24hours. Then I bunged the yeast in. I should've racked it off the skins after a couple of days, but accidentally left it a week. It tastes very very sharp, but it has a beautiful flavour underneath the tannins. Lengthy conditioning should see it right.
Apparently it's drinkable within days too. Most beer kits don't get into their peak for 6 months!
1977 Honda CG125
Poseidon
PostPosted: 22:10 - 12 Jan 2011    Post subject: Reply with quote
If it's the sugar when bottling not dissolving, try using dextrose (brewers sugar). Easy enough to come by... You could also try a small bit of golden syrup, honey, treacle etc to give it a slightly different flavour. Are you sure its sugar thats at the bottom of the bottles, and not sediment? Yeast come out of solution when fermentation stops, resulting in a pale crust at the bottom of the bottle. It's usually solid enough for you to be able to pour the beer off without disturbing it provided its been left long enough.
1977 Honda CG125
AngelGrinder
PostPosted: 22:20 - 12 Jan 2011    Post subject: Reply with quote
I'd not though about the fact it could be yeast actually, I do siphon from the bottom, but thinking about it, maybe I disturbed it before siphoning. Once it's all mixed in, do you never mix it again? Just leave it until it's ready, then siphon off?
Also, the reason my first one went bad, was because I forgot to add the sugar until 2 days after I'd put the yeast in...whoops!
Benson_JV
PostPosted: 22:26 - 12 Jan 2011    Post subject: Reply with quote
That may explain why it was sweet, the yeast not having much to chomp on (they'd have had a small amount from the kit itself) mostly died.
When you bottle it there is still yeast that gets transferred over to the bottles (which is what eats the sugar in the bottle and gives off Co2 and carbonates the beer!) so could possibly be this.
You only mix again (with a sterilised paddle) if the gravity has stuck too high to bottle. Otherwise no.
AngelGrinder
PostPosted: 22:31 - 12 Jan 2011    Post subject: Reply with quote
Cool, cheers.
If I was to buy a plastic keg, with a co2 attachment, will I be able to just fill up bottles when I need them from it? Without it going flat, loosing flavour etc? That way the bottles will be more moveable, for partys etc! Any recommendations? On the lower end of the budget scale!
Benson_JV
PostPosted: 22:36 - 12 Jan 2011    Post subject: Reply with quote
I'm going to advise against plastic kegs. They are NOT worth the money you pay.
I would far more highly recommend you get cornelius kegs (metal kegs) which are slightly more expensive in the outlay but work out cheaper and far better to own in the long run. You have the keg, a co2 tank and a tap and away you go. These you can bottle from far easier than you can from plastic kegs also.
Poseidon: Very true, I've brewed a bitter and within 4 days or so I was drinking it. I think it was at its best around a week personally!
PostPosted: 23:40 - 12 Jan 2011    Post subject: Reply with quote
I've done 5 kits 3 lager 2 cider.
First Lager was undrinkable, disgusting.
Second Cider, Just about drinkable not very nice.
Third Larger, Didn't kick off
Forth Cider, Didn't Kick off
Fifth Lager, Best of the lot, but still not that great.
I CBA with it anymore, too much hassle.
The last post was made 15 years, 271 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.18 Sec - Server Load: 1.03 - MySQL Queries: 13 - Page Size: 143.03 Kb
