Rectifier/Coil/Electrics Hell!
HD
PostPosted: 23:02 - 12 Jan 2011    Post subject: Rectifier/Coil/Electrics Hell! Reply with quote
Some of you may have read my thread about my headlight being shit. Well we nearly had it the other day, cleaned up the electrics, went for about 5 mins and went again. That was like 4 days ago. Went into town the following day and on the way back the bike just died. In the end had to push it over 4 miles in full bike gear.
Had a look over and decided it was electrical as it wasn't sparking. First thought was the ht lead so wiggled it a bit pushed and pulled this whatever. Still wasn't working. So dad thought it might be a good idea to cut the magneto wire (can't remember why) and it turned out it was all black and burnt inside dfor about an inch, maybe a bit more.
So I have ordered a new coil for it. But my problem is this:
Before 2003 Derbi Sendas were supposed to have separate regulator and flasher units but 2003> are supposed to have an all in one unit.
Mine has a separate flasher unit and regulator. For Derbi Sendas the regulator should be either a 5 or 3 pin, mine is six. And it isn't connected to anything, just earthed. Looks like there should be a block on it with wires connected that just push in. Well I cant find a block. So was the bikes electrics shit, they put a new rectifier that was compatible or something and those wires that were supposed to go to that to the coil? Then added a flasher unit?
I am so confused. And is it okay to run it like it was or was that the thing that made the coil go?
Thanks Thumbs Up
Syris the Indomitable
PostPosted: 09:50 - 13 Jan 2011    Post subject: Reply with quote
Sounds like a bit of a botch.
I could be wrong but I thought wires to the flasher unit should only come from the battery.
This is what batteries are for, they are a reprieve on the alternator which can't practically produce enough voltage to operate other things.
You may need to re jig this.
And to add to the confusion, here is a three pin rectifier.
https://cgi.ebay.co.uk/DERBI-SENDA-rectifier-3-pin-/140478686757
In Greek mythology Ichor is what immortals have in the place of blood
Those that mind, don't matter...Those that matter, don't mind. Do you agree with this?
Last edited by Syris the Indomitable on 12:26 - 13 Jan 2011; edited 1 time in total
HD
PostPosted: 17:45 - 13 Jan 2011    Post subject: Reply with quote
Hmm.
Well I cant find any looms.
As for the flasher unit, I think (bike is down dads), that it is connected to the fuse bit, which is then connected to the battery, as far as I know.
I guess it would be a bit silly to ride it how it was (with a faulty reg/rec) then?
HD
PostPosted: 20:48 - 13 Jan 2011    Post subject: Reply with quote
That's for a 125 Razz
Just going to order a regulator and put it straight into the current circuit cos it must have been Luke it at one point...
Thanks for your help guys Thumbs Up
The last post was made 15 years, 251 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.73 - MySQL Queries: 13 - Page Size: 51.36 Kb
