Starting
TheHaza10
PostPosted: 18:35 - 13 Jan 2011    Post subject: Starting Reply with quote
hello,
well i have a moped, a speedfight2, and SOMETIMES when i start it, and rev it it sounds like it misses revs. i hold down the throttle and it splutters and sounds like i keep reving from low to high but im not, and usually if i ride it for a little while it seems to go away, and becomes normal again.. any ideas?
Old Git Racing
PostPosted: 18:52 - 13 Jan 2011    Post subject: Reply with quote
A 2 stroke needs to warm up to carburate properly, once warm the misfire goes. Wont do it any good caning it when its cold.
OGR
TheHaza10
PostPosted: 21:20 - 13 Jan 2011    Post subject: Reply with quote
yeah, i just took it out for a good 10-15 mins, and it done the same thing, it goes sort of fowards then stops then foward then stops, in a jerking movement.
skatefreak
PostPosted: 22:02 - 13 Jan 2011    Post subject: Reply with quote
Is this a recent thing or has it always happened?
If its because the engine is cold then start the bike, leave it for a few minutes and when you take it out be gentile with it untill its up to temp (a couple of miles).
Once warmed up it should be fine.
As it is a 2 stroke, caning it when its cold will shorten the engines life considerably...
Luckily my NSR just dosnt have much pull above 6,000rpm untill its warmed up.
-Jvr
TheHaza10
PostPosted: 22:07 - 13 Jan 2011    Post subject: Reply with quote
erm, its happened before, the problem comes and goes. and if i leave it when its cold it doesnt tick over properly and cuts out after a short while
The last post was made 15 years, 251 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.94 - MySQL Queries: 13 - Page Size: 47.13 Kb
