Aprilia lights dont work?
121game121
PostPosted: 18:04 - 13 Jan 2011    Post subject: Aprilia lights dont work? Reply with quote
Very odd thing happened on the arilia rs 125. The dipped lights dont work no more and they did when i first rode the bike but for some reason cut out and dont turn back on anymore.
The full beam still works plus the lights upon the gauges work.
Any ideas?
PostPosted: 18:26 - 13 Jan 2011    Post subject: Reply with quote
Fuse? Bulb?
121game121
PostPosted: 18:30 - 13 Jan 2011    Post subject: Reply with quote
Fuse? Bulb?
But the high beam works when pressed?
woll
PostPosted: 18:53 - 13 Jan 2011    Post subject: Reply with quote
So low beam works?
Sounds like you just need a new bulb. The low beam filament has probably broken.
Syris the Indomitable
PostPosted: 18:55 - 13 Jan 2011    Post subject: Reply with quote
Iether there are two bulbs, one for lower beam and one for higher beam, or there are two bulb filaments in the same bulb, one for high beam and one for low beam.
The lower filament or lower bulb may have blown, that's if a fuse hasn't blown.
In Greek mythology Ichor is what immortals have in the place of blood
Those that mind, don't matter...Those that matter, don't mind. Do you agree with this?
PostPosted: 18:56 - 13 Jan 2011    Post subject: Reply with quote
Most bulbs have 2 filaments, one for low beam and one for high beam (although some bikes have separate bulbs for low and high beam).
It is entirely possible that one filament breaks while the other is still fine (probably happens 95% of the time when a headlight bulb goes). And as the low beam is used far more than the high beam that tends to be the one whose filament goes first.
The last post was made 15 years, 246 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 2.07 - MySQL Queries: 13 - Page Size: 49.12 Kb
