honda cg gear noise?
WULFSTAN
PostPosted: 18:11 - 14 Jan 2011    Post subject: honda cg gear noise? Reply with quote
alright lads right a few weeks ago was on the bike coming home from work was coming to some lights so started coming down me gears an when i came down in to 4th there was a noise from the gearbox like a grinding sound its been doing it ever since always in 4th never in nothing else ive know the clutch was going so i put it down as that went an got a new clutch today an now its doing it in most gears an its a lot louder does this mean the gearbox is fucked? thanks
Your backside is better enough for you to run again, if need be – bristle up the courage of the cornered rat, put on a bold front, and to hell with them. Bluff my boy – bluff, shift and lie for the sake of your neck and the honour of Old England
The Artist
PostPosted: 18:21 - 14 Jan 2011    Post subject: Reply with quote
Need a more detailed description.
Can you say where abouts in the engine the noise is coming from?
WULFSTAN
PostPosted: 18:28 - 14 Jan 2011    Post subject: Reply with quote
not really mate its a bit hard to pin point when your riding the bike
The Artist
PostPosted: 18:31 - 14 Jan 2011    Post subject: Reply with quote
Can you not stand next to it and rev it?
If it makes no noise then it is the clutch/gearbox.
If when riding and you pull the clutch in does the noise change/ go away?
Does it happen in neutral?
WULFSTAN
PostPosted: 18:35 - 14 Jan 2011    Post subject: Reply with quote
the only time it makes the noise is when u come down the gears so say am in 4th an i knock it down into 3rd an let the clutch out thats when it make the noise everything else with the clutch/gearbox seems fine
WULFSTAN
PostPosted: 18:39 - 14 Jan 2011    Post subject: Reply with quote
sorry should have said the noise is not constant
The Artist
PostPosted: 18:50 - 14 Jan 2011    Post subject: Reply with quote
So in 4th, clutch in, down to 3rd, let clutch out then noise?
Sounds like the clutch. Something is not right with it. I say take to bike mechanic and get them to whip the cover off and see.
Just to make sure, this ONLY happens when changing down? 3rd to 4th is fine but not down.
WULFSTAN
PostPosted: 18:57 - 14 Jan 2011    Post subject: Reply with quote
yer when i let the clutch out then the noise happens and yer it only happens when coming down 3rd to 4th is fine but not coming down
fiery tupp
PostPosted: 19:17 - 14 Jan 2011    Post subject: Reply with quote
Have you , re'set the clutch adjuster & cable adjusters ?
Did you soak the new friction plates in fresh oil ? Neutral
If you can't fix it with a hammer , use your head .
WULFSTAN
PostPosted: 19:23 - 14 Jan 2011    Post subject: Reply with quote
i dont no if the new friction plates were soaked in fresh oil as i didnt fit them an yer i have reset clutch adjuster & cable adjuster
PostPosted: 19:40 - 14 Jan 2011    Post subject: Reply with quote
Wait, so you took it to a garage to have a problem fixed, they did the work, and now it's worse? And you're asking us what you should do? Confused
What made you think the clutch needed replaced in the first place?
WULFSTAN
PostPosted: 19:50 - 14 Jan 2011    Post subject: Reply with quote
lol i know am going to have to take back to the shop tomoz an i thought i needed a new clutch because when i was trying to knock down my gears there was nothing there half the time so i was stuck in the wrong gear most of the time
clarkkent1987...
PostPosted: 08:34 - 15 Jan 2011    Post subject: Reply with quote
On the first place, had you brought it to a mechanic to check the root of the noise or you just do the checking all yourself? How much a new clutch cost? Is buying a new clutch is less expensive than paying a mechanic to know exactly the problem of your bike? Now, you said it's getting worse. So, how much money you would want to outflow by fixing it yourself? Think wisely, if you don't have enough background of fixing machinery then, my advice should be to contact an expert mechanic to have it solve rapidly. Wink
custom dirt bike graphics
WULFSTAN
PostPosted: 11:29 - 15 Jan 2011    Post subject: Reply with quote
took it back the shop today first he said my chain was to tight so i ajusted it was still making the noise so i went back again an he said oh your chain an sprockets must be fucked does this sound right ? would they make that noise if they were?
kingsknight
PostPosted: 13:24 - 15 Jan 2011    Post subject: Reply with quote
what year is your CG, how many miles has it done?
TS50 (sold) NS125F (sold) NSR125R-K (write off after 2 crashes) CG125 (nicked) XR125L-3 (Sold )-: ) DR125SM '11 (sold yay) XL125V '12 (In love with this bike) XT600E '04 (fun on the dirt)
WULFSTAN
PostPosted: 13:40 - 15 Jan 2011    Post subject: Reply with quote
its a 96 with 31000 on it
kingsknight
PostPosted: 13:55 - 15 Jan 2011    Post subject: Reply with quote
thats quite low mileage for a cg, shouldn't be anything to bad. I would of changed the oil. My mates CG had some engine noise and when he changed the oil it went away completely!
kingsknight
PostPosted: 14:05 - 15 Jan 2011    Post subject: Reply with quote
No, the noise would be there pretty much all the time if it was your sprockets!
WULFSTAN
PostPosted: 15:10 - 15 Jan 2011    Post subject: Reply with quote
yer i thought that myself just wasnt sure thanks mate
WULFSTAN
PostPosted: 15:13 - 15 Jan 2011    Post subject: Reply with quote
when the bike shop did my clutch i asked about the oil an he said yer we have put some in could the noise be there because as something as simple as the wrong oil?
PostPosted: 17:39 - 15 Jan 2011    Post subject: Reply with quote
It could, but why do you keep asking us? They should have:
1) Soaked the clutch plates in new oil before fitting.
2) Filled it with 1 litre of new 10W40 motorcycle specific oil.
Did they? Is it on the receipt? Did they offer you an empty oil bottle as evidence?
If you go in all Billy Big Bananas and say "Do this, do that", then that's exactly what they'll do, regardless of whether it's right or not. At this point, you should probably stop guessing, or asking us to guess sight-unseen, and let them figure it out, even if it costs you a bit.
Or you could tell us where you are - there may be a friendly chap nearby who can pop round and help you diagnose the problem.
WULFSTAN
PostPosted: 21:31 - 15 Jan 2011    Post subject: Reply with quote
id love to take it the shop an spead some money on it but as the bird has a baby on the way there anit much chance of that happing is there
WULFSTAN
PostPosted: 22:49 - 15 Jan 2011    Post subject: Reply with quote
will do mate already got it booked in for first thing monday before work Thumbs Up he said he will sort it
The last post was made 15 years, 162 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 2.11 - MySQL Queries: 13 - Page Size: 131.63 Kb
