Honda VT 125 Shadow Brake Shoes/Pads
astroscope
PostPosted: 17:29 - 15 Jan 2011    Post subject: Honda VT 125 Shadow Brake Shoes/Pads Reply with quote
Got the wheel indoors and had it cleaned up.
I need to get to the brakes shoes and get that inspected.
Anyone knows what I have to undo to get to the shoes/pads?
2010 Honda FES S Wing 125
Syris the Indomitable
PostPosted: 18:54 - 15 Jan 2011    Post subject: Reply with quote
Different break pads are secured in different ways. Your bike being a honda this can't be too difficult to work on.
When replacing with new pads you will need to release the bleed nipple with a spanner because you will be forcing the cylinders back in order for the new pads to fit the disk.
I found a workshop manual in French, not much good but the pictures may help.
https://www.megaupload.com/?d=6TSOAPWO
https://img510.imageshack.us/img510/9431/oie1510501677bwlniu.jpg
https://img233.imageshack.us/img233/4400/oie15104739vbbndonp.jpg
P.S, if your gunna do this which it looks like you are, I would look into how to bleed your breaks properly after replacing the new pads.
In Greek mythology Ichor is what immortals have in the place of blood
Those that mind, don't matter...Those that matter, don't mind. Do you agree with this?
astroscope
PostPosted: 19:53 - 15 Jan 2011    Post subject: Reply with quote
Oops sorry, i din't mention it's for the rear drum brakes...
how are you able to preview your images.
I can't seem to preview. They have to be downloaded.
cheers
PostPosted: 20:30 - 15 Jan 2011    Post subject: Reply with quote
You will need adobe reader.
Download and install.
This is for windows, hope you ain't got a mac.
https://get.adobe.com/uk/reader/
Then click on the link I posted on the above post, download as a free user, you will have to wait a few seconds.
I should imagine they will be fairly similar because there doesn't appear to be any other pic of other breaks, but then I didn't look that much.
They may well be more, they are situated towards the top of the PDF.
This is a PDF, zoom in a little and use the scroll down arrow to move down slowly.
Dan79
PostPosted: 21:48 - 15 Jan 2011    Post subject: Reply with quote
Since the spindle has been taken out, I would have thought the brake assembly would simply lift clear of the wheel when pulled
Previous bikes - 1984 Honda VF500 (FII) Interceptor and 1990 Yamaha RXS100
Current bikes - 1984 Honda VF500 (V30) Magna
fiery tupp
PostPosted: 22:00 - 15 Jan 2011    Post subject: Reply with quote
If you bothered to look , not a million miles away , you would have found this guide that will show you most of , if not all what you need to know Neutral https://www.bikechatforums.com/viewtopic.php?t=174773
If you can't fix it with a hammer , use your head .
astroscope
PostPosted: 22:28 - 15 Jan 2011    Post subject: Reply with quote
thanks for that.
will check it out!
Very Happy
astroscope
PostPosted: 00:03 - 16 Jan 2011    Post subject: Reply with quote
I've looked at the manual but doesn't seem to make much sense.
This is the guide I followed that helped me take the wheel off: https://www.bikechatforums.com/viewtopic.php?t=174773
Also in that guide it says that you will need to pull at the brake caliper which in turn will remove it from the wheel. I've tried that and boy is it stiff as anything.
I guess i might have to put something under the protruding alloy like a metal spanner and push at it?
cheers
The last post was made 15 years, 172 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 3.66 - MySQL Queries: 13 - Page Size: 56.42 Kb
