Aerox 50cc: Flushing Engine Oil
spatch
PostPosted: 15:09 - 15 Jan 2011    Post subject: Aerox 50cc: Flushing Engine Oil Reply with quote
Hi guys
I've put a gulp of Engine Coolant in my Oil thinking I had the Oil by mistake.
I've rode it 3 miles and its come to a holt - no bangs or anything just kinda died.
I thought as it was only a bit of coolant it would work its way through - i'm not mechanical but do you think if i flush out the oil it would be ok?
There is plenty of oil in the engine and looks the right colour etc.
What could i have done to it that would make it stop? Could it be filter? or worse something seized?
Advice appreciated!
GalaxyTramp
PostPosted: 22:23 - 15 Jan 2011    Post subject: Reply with quote
Do you mean you have put coolant into the oil feed tank? Where are you looking to see "plenty of oil in the engine"?
C
spatch
PostPosted: 22:36 - 15 Jan 2011    Post subject: Reply with quote
yes - coolant in the oil feed - put a stick in the oil feed to see how much was in it.
do ya think if i flush it all out and put new oil in it would be ok?
GalaxyTramp
PostPosted: 22:40 - 15 Jan 2011    Post subject: Reply with quote
Does the engine turn over?
weasley
PostPosted: 23:06 - 15 Jan 2011    Post subject: Reply with quote
Did this coolant go in the 2-stroke oil tank or the crankcase/gearbox? One would be Shocked and the other just Rolling Eyes.
GalaxyTramp
PostPosted: 23:15 - 15 Jan 2011    Post subject: Reply with quote
Did the overheat light come on before it stopped. I assume it will not start now?
spatch
PostPosted: 23:21 - 15 Jan 2011    Post subject: Reply with quote
the coolant went in the oil filler reservoir - not much though about a gulp.
GalaxyTramp
PostPosted: 23:41 - 15 Jan 2011    Post subject: Reply with quote
Ok so to ask again does the engine start or turn over?
spatch
PostPosted: 23:44 - 15 Jan 2011    Post subject: Reply with quote
It turns over but won't start tried afew times but didn't want to do any more damage
weasley
PostPosted: 00:05 - 16 Jan 2011    Post subject: Reply with quote
Well since water/glycol is denser than oil, the 'gulp' will have gone to the bottom of the tank, where the oil feed will have taken it to be mixed with the fuel for lubrication. You will therefore have been running with no oil at all, just coolant. The water will most likely evaporate in the engine and effectively steam clean the interior - removing any oil from the running surfaces.
Remember these engines run at what, 50:1 fuel:oil? There's not a lot of oil goes in there so any disruption to this could be problematic.
Alternatively the coolant has messed up the jetting and screwed the ability of the fuel to atomise, preventing combustion.
Whatever, you're going to need to drain and flush the oil and lines and I would have the top end and carb off for inspection and cleaning.
GalaxyTramp
PostPosted: 00:16 - 16 Jan 2011    Post subject: Reply with quote
Might sound silly but it has got fuel in the tank Surprised
The last post was made 15 years, 173 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.71 - MySQL Queries: 13 - Page Size: 63.84 Kb
