| StevenF |
 StevenF World Chat Champion
 Posted: 17:44 - 18 Jan 2011 Post subject: Fitting Radiator + Flushing System - Which Antifreeze? |
Good evening,
So I'm bored and it's poring down with rain, so I'm going to go out to the garage and fit my new radiator to my CBR. Someone mentioned that because I sealed the current hole with RadWeld, that I should flush my system to get rid of any crap; how is this done?
Do I just drain all the fluid, then fill it up with water, start the bike and let it run for 5 minutes, then drain and repeat? Should I do that with the current radiator on or the new one?
Also, do you think I should just fill it with water, or is it still cold enough that I should get some coolant added to it as well?
Thanks,
Steven ____________________ My Project - Honda CBR 600 F2/FM
| iooi |
 iooi Super Spammer
 Posted: 18:16 - 18 Jan 2011 Post subject: |
Put a hose pipe up the outlet pipe and turn it on...
That way it will push any crap out as its flowing the wrong way round the system. ____________________ Just because my bike was A DIVVY, does not mean i am...... |
| 0l0dom0l0 |
 0l0dom0l0 World Chat Champion
 Posted: 19:25 - 18 Jan 2011 Post subject: |
Disconnect old radiator, and connect new radiator. Take off the radiator cap, and with the drain bolt out, put a hose into the radiator cap, turn it on and leave it going for a few mins.
Refit drain bolt, and fill with COOLANT, or water and ANTIFREEZE. Its way too cold at the moment for straight water. It will freeze up, and you will crack the block, or f*** your water pump etc
Hope that helps  |
| StevenF |
 Posted: 19:27 - 18 Jan 2011 Post subject: |
Thanks guys! In that case I think I'll leave it till tomorrow. It's too dark to be dragging the hose out etc... ____________________ My Project - Honda CBR 600 F2/FM |
| 0l0dom0l0 |
| StevenF |
| 0l0dom0l0 |
| P.addy |
 P.addy Red Rocket
 Posted: 16:11 - 25 Jan 2011 Post subject: |
i attached the hose to my CBR's top radiator pipe and kept it on half flow.
Turned CBR on and left it running through till it was absolutely pissing out the top of the radiator. Always cold water being passed through. Did it for about 5 mins to get old oil/gunk from blown head gasket out  |
| StevenF |
 Posted: 18:59 - 25 Jan 2011 Post subject: |
Thanks again guys. I have fitted the new radiator and everything, now I just need to fill it up with Antifreeze. I was going to go to Halfords just now and get it, is there any specific stuff that I need?
Thanks again. ____________________ My Project - Honda CBR 600 F2/FM |
| Tavares |
 Tavares Borekit Bruiser
| StevenF |
| 0l0dom0l0 |
| woll |
 woll World Chat Champion
 Posted: 22:07 - 25 Jan 2011 Post subject: |
I'm thinking of doing the same when i service my bike, only problem is i don't have a hose. So what would be the best way of doing it? Just keep putting jug fulls of water in? ____________________ Current Bike- Suzuki DRZ400 SM K6
Damaged spleen, damaged kindey, 2 popped lungs, 2 broken ribs, broken face, broken wrist and 5 back fractures... remember kids walls hurt |
| Howling TerrorOutOfOffice |
| StevenF |
| Shaft |
 Shaft World Chat Champion
| StevenF |
| 0l0dom0l0 |
| 0l0dom0l0 |
| DrDonnyBrago |
| StevenF |
| 0l0dom0l0 |
 Posted: 12:54 - 26 Jan 2011 Post subject: |
| StevenF wrote: | | 0l0dom0l0 wrote: |
Check the back of the bottle. You got the coolant for pre 1998 or whatever so I expect it has been designed with that in mind.
Sounds like that person is a bit to clever for their own good. It really isn't going to matter if you use tap water or de-ionised water for the flushing process. Its when water heats up it deposits limescale. There is no tap water left after you have filled the engine with coolant, or if there is it will be so minimal that it won't make a difference. |
It says pre 1998 that's why I got it, but apparently because it's silicate based, it will damage the water pump seal.
| Quote: | Get a non silicate based coolant (the new organic acid based ones i.e. Halfrauds pro coolant), flush the old stuff out properly and refill with the new stuff. To flush, pop out the drain screw and stick the hose in the rad filler; you might need to remove your coolant bottle and wash it out if it doesn't get completely empty when you drain the rest of the system. Rinse the coolant bottle either way.
To flush, the tap is fine, it isn't in there to stay and it doesn't get hot whilst in there. Use deionised to make up your coolant but don't waste your cash on deionised water to just to flush it with. |
I have already got the stuff I posted and used it, which apparently is the wrong stuff. I think I'll keep it in for a month or so and then do it again when I can be bothered.
I don't know where flushing the system with deionised water came from, I used a hose. I only got the deionised water to mix with the antifreeze. |
It says in that site you posted, to use de-ionised water to flush, so that's where I got that from lol.
I have never heard of this problem before, do you think its worth ringing you local Honda garage to see if they have heard of the problem?
| DrDonnyBrago |
| StevenF |
 Posted: 12:57 - 26 Jan 2011 Post subject: |
Ok glad that has cleared up I'll give my local Honda Dealership a little email to see what they say.
Thanks for the help  ____________________ My Project - Honda CBR 600 F2/FM |
| Tavares |
The last post was made 15 years, 294 days ago. Instead of replying here, would creating a new thread be more useful? |
