Hi-fi advice. A simple one.
c_dug
PostPosted: 11:29 - 19 Jan 2011    Post subject: Hi-fi advice. A simple one. Reply with quote
Can I run two hi-fi's in to one set of speakers just by splicing the output wires together in a kind of long Y shape?
PostPosted: 12:00 - 19 Jan 2011    Post subject: Reply with quote
It makes sense that you could, the sound quality would be shit and if you had both running at the same time it would make a horrible noise and maybe even blow them.
The more importantly question is why would you want to?
cagiva gezzer
PostPosted: 12:05 - 19 Jan 2011    Post subject: Reply with quote
I run two sets of speakers (kitchen & garden) off one hi-fi and swap between them using a 'three pole, double throw" toggle switch.
I assume you could do the reverse ?
c_dug
PostPosted: 12:06 - 19 Jan 2011    Post subject: Reply with quote
So I can do remixes.
Not really, I have 3 hi-fi's and 2 sets of speakers, my friend has my the one without the speakers in his shed (it has sofas and a telly etc...) but he doesn't have a set of speakers with it. I have two set up in my room because one of them is pretty crappy quality compared to the other, but the good quality one doesn't have and alarm clock.
So at the moment I use the bad one for a radio alarm clock and the good one for music. I was going to give my friend the speakers from the crappy one and wire the alarm hi-fi up to the other ones speakers.
Hopefully that makes sense.
PostPosted: 12:34 - 19 Jan 2011    Post subject: Reply with quote
Buy a better alarm clock and ditch the crap hifi. Will save your electrosparky and give you extra space.
Something cheap and cheerful like this
https://www.argos.co.uk/static/Product/partNumber/9241688/c_1/1%7Ccategory_root%7CHome+entertainment+and+sat+nav%7C14419512/Trail/searchtext%3EALARM.htm
karoshi
PostPosted: 13:11 - 19 Jan 2011    Post subject: Reply with quote
As Chris said the output quality would likely suffer if you spliced them together, you need an audio input switcher, something like:
this: maplins link
or this: maplins again
or this: ebay link
Smile
Well, I've wrestled with reality for 35 years, Doctor, and I'm happy to state I finally won out over it. - Elwood P. Dowd
PostPosted: 13:32 - 19 Jan 2011    Post subject: Reply with quote
All more expensive than a new alarm clock Laughing
Codemonkey
PostPosted: 13:38 - 19 Jan 2011    Post subject: Reply with quote
Its quite possible that you could damage the output stage in the amplifier of the other hifi if you played the music loud enough from the other. As said above, get a switcher.
karoshi
PostPosted: 13:58 - 19 Jan 2011    Post subject: Reply with quote
yeah but it's cooler.. actually rather than buying one you could just run the wires up to a massive Dr Frankenstein style two position blade switch on the wall..
https://www.speshul.org/random/switch.jpg
https://www.speshul.org/random/its_alive.jpg
.. you would have to scream "IT'S ALIVE!!" when switching over though Very Happy
The View Askew
PostPosted: 22:22 - 19 Jan 2011    Post subject: Reply with quote
Yes, just don't power them both on at the same time.
I would get a switchbox personally to avoid accidental use of them both.
The last post was made 15 years, 253 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.27 Sec - Server Load: 0.87 - MySQL Queries: 13 - Page Size: 65.68 Kb
