Carburated vs Fuel Injection?
jonnyboy
PostPosted: 09:54 - 20 Jan 2011    Post subject: Carburated vs Fuel Injection? Reply with quote
Looking at upgrading my bike soon and I'm still fairly new to bikes so if the answers are obvious I apologise, but - what are the advatages / disadvantages of carbs vs fuel injection? The reason I'm asking is it might inform my decision about what bike to buy. My current bike is carburated and messing about with the choke irritates me at times. Ive had a look on google but a lot of the info is either too technical for me or relates to cars not bikes. Main things i'm interested in are maintenance and reliability. Thanks in advance!
PostPosted: 10:03 - 20 Jan 2011    Post subject: Reply with quote
Carbs work fine. For years with the crude injection systems used on cars one of the first things to do when trying for more performance was to dump the fuel injection and fit carbs. Carbs are cheap (to the bike makers) and easily fettled by anyone (OK, they might make a pigs ear of it).
However injection systems are simpler in a lot of ways. Simpler for the rider to operate. While you might have a fast idle lever (like a choke), on its own it won't richen the mixture so no chance of coking the plugs up leaving the choke on.
Maintenance wise the fuel injection is probably simpler. Both should be balanced occasionally. Both have filters that should be changed occasionally. Most bikes have CV carbs where the diaphragms can wear and puncture.
Down side with fuel injection is that one small fault is probably more likely to make the bike unrideable. Also working out what the fault is with injection might be more difficult (on the other hand it might have a self diagnosis system to make it easier to find the fault).
Not sure that actually helps as there are a lot of different injection systems and carb around, and so plenty of individual differences.
hmmmnz
PostPosted: 10:12 - 20 Jan 2011    Post subject: Reply with quote
im a spark but i'd still rather rely on carbs,
you can just always always make it home with carbs, when fi goes wrong.... it really goes wrong,
its almost never the mechanical parts at fault, so generally not user servicable,
but on the plus side with fi,
its easily tunable, its pretty reliable, and normally requires no maintance,
the humans are dead
I kick arse for the lord
CaNsA
PostPosted: 10:15 - 20 Jan 2011    Post subject: Reply with quote
Carbs have soul.
ollieholt
PostPosted: 10:29 - 20 Jan 2011    Post subject: Reply with quote
you can do nice backfires with carbs and a kill switch Thumbs Up
fuel economy is much better with fuel injection IMHO, some earlier systems are very notchy and rough low down the rev range. carbs tend to give a smoother output then older injection models.
it all depends on what your buying i suppose.
the choke is irritating you? is it set up right? mine does the job perfectly.
Laughing < This? Well this is just a day brightner.
Mr Hammers
PostPosted: 11:34 - 20 Jan 2011    Post subject: Reply with quote
I've found in my limited injection experience that they're more reliable than carbs, but I much prefer the look of carbs on an engine and am always fascinated with their workings.
As an example, I have an Italjet that has a carb problem, I've got a KLX not running properly which I'm sure is the carb, and whenever I've had a problem on the Bandit, it's always been....you guessed it...the carbs.
But given the choice, I'd *still* go for carbs over injection. As CaNsA says, they have soul.
A Guide To Powerbands
PostPosted: 12:04 - 20 Jan 2011    Post subject: Reply with quote
I've found carb's to be smoother but more of a pain to work with, I don;t think I have ever known an injector to fail. Plus it is easier to tune injectors. I'd go with injector for reliability and simplicy (from the users POV)
D O G
PostPosted: 12:23 - 20 Jan 2011    Post subject: Reply with quote
I'd go for FI too, less to go wrong in my mind, especially on the more recent systems after years of development, easier to tune, more flexible (IMO) and smoother than carbs too.
Suspect better consumption than carbs also.
jonnyboy
PostPosted: 13:50 - 20 Jan 2011    Post subject: Reply with quote
thanks for all the info. on one hand, i have very little time for maintenance or trying to fix things myself, so FI would seem logical, but on the other the bikes i like within my budget are carburated ( i think) - im looking at thundercats (98-00), zx6r (98-00) and zx9 (97-98). i cant afford a decent vfr800 or sprint st 955i unfortunately! the only FI 600 - 1000cc sports tourer i can find for less than £1.5k is a triumph tt600 which wouldnt be my natural first choice. my old teapot has put me off suzukis which limits the choice.
mistergixer
PostPosted: 14:22 - 20 Jan 2011    Post subject: Reply with quote
I went from a carbed SRAD to a FI'd K5 750, here's what i noticed:
K5 was far easier to start, but didn't do backfires.
SRAD was a bitch to start, especially in cold/damp conditions, but did ORSUM backfires.
Personally, i'd pick the FI'd bike, as i needed to start the engine more than i needed to do backfires.
Space Monkey #7
stevekingchef
PostPosted: 19:12 - 20 Jan 2011    Post subject: Reply with quote
hi
theres not too many f.i bikes that fit into your needs,it seems you had trouble with your carbs!!
f.i is easier to play around with if you buy a power commander or tune boy,
hopefully you got my pm i sent im not sure if they are sending via my mob.im on my laptop now
steve
evoboy
PostPosted: 19:13 - 20 Jan 2011    Post subject: Reply with quote
CaNsA wrote:
Carbs have soul.
+1
APT Motorcycles
Mrs Vale46
PostPosted: 19:31 - 20 Jan 2011    Post subject: Reply with quote
Carbs are more fun to play with! And they arent as difficult as people make out.
jonnyboy
PostPosted: 19:53 - 20 Jan 2011    Post subject: Reply with quote
thanks steve, ive replied to your pm. appreciate all the comments about carbs having more soul etc but my problem is i dont have any spare time to play around with a bike, i only just get away with lubing my chain once a week! i need something i can just jump on and start easily that will get me to work and back every day. i borrowed a sprint st for a while and the convenience of not worrying about the carbs and choke working properly (admittedly i was comparing it to my old gsxf!) was very appealing. a quick search on the net though tells me i'll struggle to get a fuel injected bike min. 600cc for less than £1500. so might need to get a carburated bike after all!!!!
D O G
PostPosted: 20:11 - 20 Jan 2011    Post subject: Reply with quote
I wouldn't let the fact it had carbs put me off tbh - FI would be preferable, but not essential.
Benson_JV
PostPosted: 20:34 - 20 Jan 2011    Post subject: Reply with quote
In my limited experience it seems I prefer FI in lower CC bikes (125) whereas anything above I prefer carbs. Laughing Just my feelings.
woodyfjr
PostPosted: 20:45 - 20 Jan 2011    Post subject: Reply with quote
Carbs arnt that bad there like everything else they need attention now & then, I would prefer carbs on the FJR but the EU regs makes it impossible.
Fuel economy FJR av 50mpg old FJ12 48mpg so not much in it
When an FI system goes wrong you'll wish you had carbs as FI can cost a fortune when it goes wrong and you cant limp home.
I had a problem with the FJR it turned out to be the FI system needed at lest 12.5v just to operate (duff battery 12.4v) where as a carbed bike would have still got me home.
As for which bike to buy what about a Divvy 6 or 9 both easy to work on air cooled and cheap buy and the 9 has a shaft.
If its one of the bikes you listed I'd have a cat a very good bike.
If you don't pay your exorcist you can get repossessed.
If you have to rev it! Don't Buy it!
the grim reaper
PostPosted: 20:52 - 20 Jan 2011    Post subject: Reply with quote
Carbs are relatively easy to understand and once you do that you're most of the way there to being able to service them yourself. FI was introduced to reduce emissions, primarily, as well as simplifying what's under the bonnet/tank.
It's easier to fine tune FI to a new exhaust, although you are looking at the extra expense of a power commander or similar. Carbs you can re-jet and change needles but they're not as infinitely tuneable.
Either work fine, don't concern yourself with it too much.
Grim
neil.
PostPosted: 21:18 - 20 Jan 2011    Post subject: Reply with quote
In my experience, my YBR is the carbed version, I've put 35'000 miles on it, riding all year round over the last 3 years. Never once had issues with it failing to start or carb icing (the carb has a heating element built in, which most modern carbs have) etc, even in the recent really cold weather we've had. In fact, it's been very reliable and the engine has always ran smoothly.
The only thing that happened was the screws holding the float bowl rattled loose over time so I was leaking fuel. Fixed with a bit of blue Locktite and spring washers, which should prevent that happening again. I personally like having a component that I can repair/diagnose problems with and fix cheaply rather than a computer controlled system that is expensive to fix and not 'user' serviceable. When I reassembled it, I was surprised to notice it was very clean inside, probably because I use the bike nearly every day for long journeys. No fuel pump to go wrong (just a hand operated, gravity fed tap) etc.
weasley
PostPosted: 22:03 - 20 Jan 2011    Post subject: Reply with quote
I have a 13 year old Thundercat and the carbs have never caused a second of problem. In fact when I bought it 8 years ago it had been sat in a garage for 12 months and not started - you hear all sorts of stories of fouled carbs, stale fuel and the like but once the battery was charged it fired and ran straight away and has done ever since. Yes, you have to balance the choke and throttle to start it but it has never not started and still returns over 50 mpg when needed.
I once rode a CBF1000 and I found the off-on throttle transition really jerky - the Cat will react very progressively to the tiniest throttle input.
Alex A
PostPosted: 23:14 - 20 Jan 2011    Post subject: Reply with quote
Carbs are a pain in the ass when they play up, but they're typically much better at delivering smooth fuelling than injectors (especially at low RPM).
Then again, many newer FI systems are superb. And you can usually make them better with a power commander. Which is much easier than rejetting carbs (though not necessarily cheaper). They're also more consistent and reliable IME.
I'd take a decent FI system over carbs any day.
Teflon-Mike
tl;dr
PostPosted: 01:21 - 21 Jan 2011    Post subject: Reply with quote
Carburettors & Fuel injection do the same job. They mix petrol & Air in the proportion needed to make a 'charge' that will burn in the engine. Nothing particularly mystical about either system, in the often misguided belief that they are the key to phenominal extra power or to unlimited ecconomy... they are simply a fancy measuring & mixing system.
Carburettors are an 'analogue' system, normally working on air-speeds and pressure differences. fuel Injection is a digital system, controlled by a micro-processor, worked from electro-mechanical sensors.
Difference is a bit like, old fasioned vynal records, to CD or MP3.
Vynal, with a continually varying 'signa' gives a 'perfect' reproduction of whats put on the plastic. Digital, takes a 'sample' of the original, and notates it, then reproduices the 'average' of the sample. Its not a 'real' reproduction, but a synthesised one.
For a hi-fi buff, vynal is king, becouse it has a greater dynamic range of reproduced sound, more colour and texture in what comes out the speakers, where digital is more 'clinical', but easier to use, and unlike records that wear out and get scratched, Digital either works or it dont!
I like carbs, but apreciate EFi. I wouldn't choose a bike based on the carburation system.
It makes little odds and theres far more important stuff to consider.
Alex A
PostPosted: 08:46 - 21 Jan 2011    Post subject: Reply with quote
To go completely OT, I've got to say that's very much an oversimplification. I could probably be considered a 'hi-fi buff'. Have been for years, and I've had hundreds of bits of kit pass through my hands over that time.
Yes, vinyl is probably my first choice. But it's not because it has greater dynamic range: CD has a huge capacity to accommodate dynamic range. It's just that recording engineers and re-masters for CD tend to sacrifice that dynamic range in favour of bringing everything to the maximum level (which makes it more interesting on a shitty system that can't accommodate dynamic range range - like a car system, or ipod etc.). And that's more to do with fashion than it is to do with format.
If you think CD has limited dynamic range, just listen to something like Dire Straits Alchemy, or a well recorded classical piece on a decent system. Every nuance will be there, unexaggerated, and cast proportionately against the crescendos and peaks of the rest of the recording. In fact, it's probably easier for a CD (or 44.1kHz PCM) as a format to consistently replicate greater dynamic range than a record, as with vinyl it really does depend on the ability of the turntable, arm and cartridge, and whether it's all been properly calibrated. Otherwise, it won't pick up those nuances. And.. that's assuming that the original cut of the record was also done to very high standards. Otherwise, the dynamic range of the 'master', and thus the copies, will be limited. CD has no such technical barriers, beyond the mastering. And, the more common single disc LPs with lots of minutes of music recorded to them tend to be somewhat compressed (there isn't much real estate dedicated to each track), which makes dynamic range (and detail/depth) difficult to store and retrieve.
Colour and texture? Well, subjectively, perhaps. Though not necessarily consistently. And the perception of these things is usually associated with poor setup. Get a quality, properly set up deck, and it can be arguably just as 'clean and clinical' as CD is often claimed to be. These are just subjective interpretations of system, not format, limitations.
Records don't wear out unless you put too much weight on the cantilever. If you balance the arm correctly, it will simply read the record, nothing more. And records don't get scratched unless you've got an idiot scraping the needle across them because they can't change tracks properly. Or unless they're flung unceremoniously on the side, and not returned to their sleeve once removed from the deck. I've got many records that I bought new and have played many times. They are neither worn nor scratched.
Added to all that, it's much easier to get a great sound from CD. For a couple of hundred quid, you can get a real quality, sorted CD front end. Spending hundreds or thousands more will only reap very marginal benefits. Spend a couple of hundred on a record deck, arm, cartridge and phono stage, and you'll be nowhere near that CD player at the same money. There's much better scope for return on greater investment. But, just spending money doesn't guarantee you a quality front end. You need to get it meticulously set up, and there are so many areas where you could go wrong here: Poor cartridge/phono stage loading, poor step up transformer, poor arm balance, poor alignment, poor tracking, poor belt tension (if it's belt), even not getting the whole rig perfectly level is a major problem. Vinyl only really shines if you are prepared to spend serious time and money getting it spot on. In that respect, you could draw some parallels with old nackered carbs. But new, factory setup carbs are much more 'plug and play' than vinyl will ever be.
I suppose I choose vinyl for two reasons:
First, most vinyl recordings tend to be better mastered in order to make the most of a true high fidelity system. Especially old records, the CD versions of which have been 're-mastered' and often ruined in this respect. 12" singles also sound absolutely stonking on record, because they have an entire 12" wide track dedicated to about 8-10 minutes of music at 45RPM. It's very easy for a turntable/arm/cartridge to pick up the detail and dynamics from such a large track. And they're fun to mix with.
Second, by account of being a pain to get up and change track, vinyl encourages you to listen through entire albums, rather than skip to familiar tracks at the expense of perhaps discovering a hidden gem or two. I'm a big fan of albums, and not just singles, and appreciate the way that vinyl encourages exposure to entire albums.
PostPosted: 09:01 - 21 Jan 2011    Post subject: Reply with quote
Alex A wrote:
To go completely OT, I've got to say ...........
Well apple told me the ipod was the best, so yah boo sucks to you Sick
Teflon-Mike
tl;dr
PostPosted: 21:46 - 21 Jan 2011    Post subject: Reply with quote
It would have been an 'over-simplification' if I was trying to explain why records may sound better than CD's.... but I wasn't!
It was an 'analegeouse-simplification' ......
The last post was made 15 years, 302 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.09 Sec - Server Load: 0.53 - MySQL Queries: 13 - Page Size: 138.71 Kb
