| burnleyman188... |
 burnleyman188... Two Stroke Sniffer
| clancy |
 clancy World Chat Champion
| burnleyman188... |
| N cee thirty |
 N cee thirty Banned
| clancy |
 Posted: 01:11 - 21 Jan 2011 Post subject: |
that ^^
a bump start is just, turn ignition on ( dont try starting the bike just have it on) knock it into first or something and push the bike with the clutch in. build up a bit of speed then when its rolling let the clutch out and give it some revs and it should come alive  ____________________ KLX 300r |
| burnleyman188... |
| clancy |
| pits |
 pits World Chat Champion
 Posted: 01:45 - 21 Jan 2011 Post subject: |
Dead alternator, your bike is using the battery to run, when there is no power left in the battery it wont run, as it needs power for the spark plug, normally your bike would use the power supplied by the alternator to keep it running and to top the battery up.
Simple check with a thing that I have just forgotten the name, that checks voltage and stuff with two prongs on a wire, god damn it, anyway, measure the current going through the battery and see what the alternator is putting into the battery when it is running, it should stay about the same, but if the voltage is dropping then you are running on the battery.
Also we have a forum aptly named The Workshop |
| N cee thirty |
 N cee thirty Banned
 Posted: 01:48 - 21 Jan 2011 Post subject: |
| pits wrote: | Dead alternator, your bike is using the battery to run, when there is no power left in the battery it wont run, as it needs power for the spark plug, normally your bike would use the power supplied by the alternator to keep it running and to top the battery up.
multimeter ?
i thought it was the alternator aswell,could be bad wiring ____________________ '00 Aprilia RS50 > '92 Honda CG > '99 Yamaha Fazer > '91 Yamaha RXS > '79 Suzuki X5 > 01' Honda Cg > 07' Honda Cg > 82' Kawasaki Z200 > suzuki gsxr 400 gk73a > honda vfr 400 NC30 Mod 2 Passed 09/06/2011
Jewlio Iglesias wrote: I actually did vote BNP once |
| CaNsA |
 CaNsA Super Spammer
| pits |
 Posted: 02:47 - 21 Jan 2011 Post subject: |
| rob yarrr wrote: | | pits wrote: | Dead alternator, your bike is using the battery to run, when there is no power left in the battery it wont run, as it needs power for the spark plug, normally your bike would use the power supplied by the alternator to keep it running and to top the battery up.
multimeter ?
i thought it was the alternator aswell,could be bad wiring |
That's the fucker, I wanted to say Ammeter but I knew it was wrong and so was voltmeter, as they only read amps or volts and of course we want multiple reading, what a mind blank though, I could picture it in my head. |
| Paulington |
 Paulington World Chat Champion
 Posted: 04:54 - 21 Jan 2011 Post subject: |
I am in agreement with Pits, it seems you have a dead alternator.
Your bike is using the charge from the battery to run, all the time, however the alternator provides charge to the battery as it generates an electric current by spinning a rotor around inside a stator. This provides electricity to charge the battery.
However, your alternator is not working for some reason, therefore the bike is running on charge from the battery and that will get used up quick. Since the alternator is not working it is not providing charge back to the battery so the bike has no power to run.
Think of it as a fountain, if it has water (electricity) in it, then it will keep going, if it has no water in it, the fountain won't work.
As Pits said, the easy way to diagnose this is to check the current across the battery and compare it to the current across the alternator with a multimeter, if there is a large difference then there is your problem.
Take it to a dealership and get it looked at. . ____________________ "Four wheels move the body, two wheels move the soul."
CBT: 27/08/08. Theory: 04/09/09. Module 1: 16/09/09. Module 2: 01/10/09. |
| N cee thirty |
 N cee thirty Banned
| ollieholt |
 ollieholt World Chat Champion
 Posted: 12:45 - 21 Jan 2011 Post subject: |
is there no kick start of newer cg's?! rubbish if not! my old hack was a beuty i have never heard of anyone killing a cg, you can run them on grits and lime juice with sand as oil. ____________________
< This? Well this is just a day brightner. |
| truslack |
 truslack World Chat Champion
| ollieholt |
 Posted: 13:01 - 21 Jan 2011 Post subject: |
sue me for what? id didnt say how long it would run for or under what circumstances
ok then, chip oil and meths.  ____________________
| pits |
| hellbound |
 hellbound World Chat Champion
| ollieholt |
| pits |
| clancy |
The last post was made 15 years, 254 days ago. Instead of replying here, would creating a new thread be more useful? |
