Recommend me an alarm.... please :)
maria383
PostPosted: 12:51 - 21 Jan 2011    Post subject: Recommend me an alarm.... please :) Reply with quote
Hey guys,
I was wondering if someone could give me a few ideas on a decent alarm/lock for my bike. As I've only used chain locks previously, I'm not really sure where to start!
Thanks, Maria
Happiness is realising you have another gear left
ollieholt
PostPosted: 12:58 - 21 Jan 2011    Post subject: Reply with quote
I have a data tool top of the range thing, dealer fitted it when my other went bang (toad)
It does slowly drain battery (took 8 weeks to drain to a point of no start) so not a lot. Works great not to sensitive, auto arms the immobiliser after 30 seconds. Would recommend it.
A physical deterrent is always best first line. the data tool has a flashing led on the tail of the bike which is good.
A big dirty lock and chain is a great deterrent but they are easily foibled within a couple of minutes with a massive pair of bolt cutters. thieves are opportunists though, if you bike has a lock and the one down the road doesn't you know which they will be more likely to go for.
Laughing < This? Well this is just a day brightner.
Imonster
PostPosted: 13:26 - 21 Jan 2011    Post subject: Reply with quote
Don't get an alarm - poxy things that can go wrong and as said above drain the battery. While a lot of "sold secure" chains can be cropped relatively easily, have a look on youtube for demos of Almax chains. They're expensive, but ridiculously tough. Though only as good as the thing you're chaining it too.
I really want to get rid of the Datatool that came with my bike, but scared of immobilizing the thing for good if I mess it up.
Those who make peaceful revolution impossible will make violent revolution inevitable.
Ingah
PostPosted: 07:07 - 22 Jan 2011    Post subject: Re: Recommend me an alarm.... please :) Reply with quote
maria383 wrote:
Hey guys,
Thanks, Maria
My recommendation, and other discussion, can be found here:
https://www.bikechatforums.com/viewtopic.php?t=200693
-- Ingah
PostPosted: 09:02 - 22 Jan 2011    Post subject: Reply with quote
Bought 2 of these over a week ago
Cant say how well they last obviously, but they are both VERY loud and simple to install.
https://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=200379831192&ssPageName=STRK:MEWNX:IT
Very sensitive too!
weasley
PostPosted: 09:08 - 22 Jan 2011    Post subject: Reply with quote
I don't subscribe to this "something else to go wrong" mentality. If we all thought that we'd still be on Velocettes and Bantams, none of this new-fangled fuel injection and electric starters.
If it is designed, built and (crucially) installed correctly then there shouldn't be a problem. I have had a Datatool System 3 on my bike for 8 years and it has worked flawlessly, and still does. It will 'sleep' if the battery gets below a certain level and has never left me without power. I do now use an Optimate but that's because I can and the bike does go for long stints unridden.
I'm not saying alarms and immobilisers are perfect, but if you know how to use them and what they do, they shouldn't get in the way of you biking pleasure.
Des
PostPosted: 09:14 - 22 Jan 2011    Post subject: Reply with quote
I agree. I knew 2 other people with Datatool alarms, and me. One of them got stranded when it wouldn't dis-arm. The other one melted! Fortunately someone noticed the smoke and they stopped before it did much damage to the bike.
I un-installed the one I had on my bike soon after. It wasn't that hard but it was time consuming. The alarm kept firing off all day while I was doing it, and no-one batted an eyelid.
1998 Fireblade
1988 VFR
Paxovasa
PostPosted: 09:20 - 22 Jan 2011    Post subject: Reply with quote
Should have put it in service mode Rolling Eyes Wink
My bike has a datetool system 3 and apart from the fuse going on it. I have not had a problem and it has saved my bike on one occasion that I know of Thumbs Up
Des
PostPosted: 09:22 - 22 Jan 2011    Post subject: Reply with quote
If I'd known how to, I would have done Wink
1998 Fireblade
1988 VFR
Paxovasa
PostPosted: 09:25 - 22 Jan 2011    Post subject: Reply with quote
All you had to do was ask Razz
Igniton on and press the key fob (like you would to alarm it).Then after the beeps turn the ignition off. Alrm is now in service mode.
But I guess you already knew how to do it.
Davie J
PostPosted: 09:54 - 22 Jan 2011    Post subject: Reply with quote
Very sensitive too!
Fitted one of these 3/4 months back.
Have it set to medium sensitivity.
It's managed to scare somebody away as I went out one morning to see my cover and the disc lock reminder cable off.
Kwak Z750R Black Edition
Marauder 125 K3 (Murdered by a Megane), Varadero 125 V7 (sold), Varadero Thou (Sold), CB500S (Sold).
Des
PostPosted: 10:08 - 22 Jan 2011    Post subject: Reply with quote
Ah right, no I didn't know that - it was about a year ago that I took the alarm off, so I wasn't on here to ask! And even then, I didn't know about 'service mode'. Maybe I should have read the manual.... Rolling Eyes
Useful tip if I ever buy a bike with a Datatool alarm fitted though.
1998 Fireblade
1988 VFR
ollieholt
PostPosted: 10:32 - 22 Jan 2011    Post subject: Reply with quote
My data tool has been great and it wasn't a toad as I said in a earlier post, I used to have a meta. Hunk of junk that turned out to be.
Mine also has the sleep modes when the voltage gets lower but eventually it goes drain enough off so as not to be able to press the starter and go. Like I said it did take weeks for that to happen though.
The Tot
PostPosted: 10:57 - 22 Jan 2011    Post subject: Reply with quote
I had a cyclone alarm on my ZX6R - foolishly wired in the remote start/immobiliser function. Something went wrong with the wiring and it took out 2 very good batteries! Took it to my mechanics and he said, despite using the relay, this alarm draws way too much current from the main ignition feed when it's active. It lasted a month after I realised I had to keep buying new batteries! Even an optimate wouldn't revive them! So if you ARE buying a cyclone alarm, just wire it into the terminals and use it as a motion sensor alarm.
I wired in my Acumen 911 alarm onto my bike. Worked fine for a year then on the way home from work, my hazards started flashing - realising I don't have a hazard switch, it got me thinking, the only thing I've got wired into the indicators is my alarm. Rightly so, I got home and it refused to arm!
So rule of thumb for me is to now just use chain, cover and disk lock. I've got one of those Xena Alarms but they're just for show. The batteries wear out too quickly when it's cold so I don't bother with it now. Result is that I've cracked my mudguard twice!
So my 2 cents is, just get a cheapo alarm and combine it with your other security! Keep a smart charger at bay too. I'm glad the Blade has a factory fitted immobiliser so I don't have to rely on a combo alarm/immobiliser. At least with my self-fit Accumen 911, I just whipped it out without having to dissect my wiring loom. Same story goes for the Cyclone alarm.
Never argue with autism
ollieholt
PostPosted: 12:34 - 22 Jan 2011    Post subject: Reply with quote
https://www.autoevolution.com/news/possession-of-motorcycle-theft-tools-illegal-in-california-29057.html
They have made there way over here. Be alert, a factory immobiliser isn't that much of a problem these days. Always use a big dirty chain, puts the TWOCers on the back foot but they are not fool proof.
The last post was made 15 years, 302 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 0.34 - MySQL Queries: 13 - Page Size: 91.21 Kb
