| maria383 |
 maria383 Scooby Slapper
| ollieholt |
 ollieholt World Chat Champion
 Posted: 12:58 - 21 Jan 2011 Post subject: |
I have a data tool top of the range thing, dealer fitted it when my other went bang (toad)
It does slowly drain battery (took 8 weeks to drain to a point of no start) so not a lot. Works great not to sensitive, auto arms the immobiliser after 30 seconds. Would recommend it.
A physical deterrent is always best first line. the data tool has a flashing led on the tail of the bike which is good.
A big dirty lock and chain is a great deterrent but they are easily foibled within a couple of minutes with a massive pair of bolt cutters. thieves are opportunists though, if you bike has a lock and the one down the road doesn't you know which they will be more likely to go for. ____________________
< This? Well this is just a day brightner. |
| Imonster |
 Imonster World Chat Champion
| Ingah |
 Ingah World Chat Champion
| P.addy |
 P.addy Red Rocket
| weasley |
 weasley World Chat Champion
| Des |
 Des Borekit Bruiser
| Paxovasa |
 Paxovasa World Chat Champion
 Posted: 09:20 - 22 Jan 2011 Post subject: |
| Des |
 Des Borekit Bruiser
 Posted: 09:22 - 22 Jan 2011 Post subject: |
| Paxovasa |
 Posted: 09:25 - 22 Jan 2011 Post subject: |
All you had to do was ask
Igniton on and press the key fob (like you would to alarm it).Then after the beeps turn the ignition off. Alrm is now in service mode.
But I guess you already knew how to do it. ____________________ Suzuki GSF600 K3 (in the fastest colour, black). |
| Davie J |
 Davie J Scooby Slapper
 Posted: 09:54 - 22 Jan 2011 Post subject: |
Fitted one of these 3/4 months back.
Have it set to medium sensitivity.
It's managed to scare somebody away as I went out one morning to see my cover and the disc lock reminder cable off. ____________________ Kwak Z750R Black Edition
Marauder 125 K3 (Murdered by a Megane), Varadero 125 V7 (sold), Varadero Thou (Sold), CB500S (Sold). |
| Des |
 Des Borekit Bruiser
| ollieholt |
 Posted: 10:32 - 22 Jan 2011 Post subject: |
My data tool has been great and it wasn't a toad as I said in a earlier post, I used to have a meta. Hunk of junk that turned out to be.
Mine also has the sleep modes when the voltage gets lower but eventually it goes drain enough off so as not to be able to press the starter and go. Like I said it did take weeks for that to happen though. ____________________
| The Tot |
 The Tot World Chat Champion
 Posted: 10:57 - 22 Jan 2011 Post subject: |
I had a cyclone alarm on my ZX6R - foolishly wired in the remote start/immobiliser function. Something went wrong with the wiring and it took out 2 very good batteries! Took it to my mechanics and he said, despite using the relay, this alarm draws way too much current from the main ignition feed when it's active. It lasted a month after I realised I had to keep buying new batteries! Even an optimate wouldn't revive them! So if you ARE buying a cyclone alarm, just wire it into the terminals and use it as a motion sensor alarm.
I wired in my Acumen 911 alarm onto my bike. Worked fine for a year then on the way home from work, my hazards started flashing - realising I don't have a hazard switch, it got me thinking, the only thing I've got wired into the indicators is my alarm. Rightly so, I got home and it refused to arm!
So rule of thumb for me is to now just use chain, cover and disk lock. I've got one of those Xena Alarms but they're just for show. The batteries wear out too quickly when it's cold so I don't bother with it now. Result is that I've cracked my mudguard twice!
So my 2 cents is, just get a cheapo alarm and combine it with your other security! Keep a smart charger at bay too. I'm glad the Blade has a factory fitted immobiliser so I don't have to rely on a combo alarm/immobiliser. At least with my self-fit Accumen 911, I just whipped it out without having to dissect my wiring loom. Same story goes for the Cyclone alarm. ____________________ The Tot 2019 Z1000SX - 2007 R1
Never argue with autism |
| ollieholt |
The last post was made 15 years, 302 days ago. Instead of replying here, would creating a new thread be more useful? |
