Car brakes
PostPosted: 17:19 - 24 Jan 2011    Post subject: Car brakes Reply with quote
Any ideas on car brakes where the pedal slowly goes down (not to the floor, but say about 1/4 normal travel, 1/2 slowly going down and then 1/4 distance to the floor) without using any fluid? Only things I can think of would result in it using fluid except possibly ABS pump.
PostPosted: 17:33 - 24 Jan 2011    Post subject: Reply with quote
Brake balance valve? I had similar on my MX3, and although I didn't keep it for very long it had a similar issue. Looking at web forums they said it was the front/rear brake balance valve sticking in one position.
British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F
Teflon-Mike
tl;dr
PostPosted: 17:36 - 24 Jan 2011    Post subject: Reply with quote
Whats the motor.
Be duel circuity, as like, so if compound master cylinder could be a seal, fluid passing from one circuit to the other. alterbnatively a failure in the bias or bias relief valve.
You say ABS, whats the arrangement?
Could be a sticking ABS relief valve, rather than the pump.
PostPosted: 17:39 - 24 Jan 2011    Post subject: Reply with quote
Mmm, possible. With the bias valve stuck it almost blocking off the back it could take a while to push fluid to the back. But wouldn't expect it to take that much fluid. Would also expect it to take far longer to push the fluid forward to allow the same problem when trying the brakes again (same with a crushed brake line).
PostPosted: 17:41 - 24 Jan 2011    Post subject: Reply with quote
Master cylinder seal failed and with 2 circuits does sound the most likely thinking about it.
Not my car so not got any details on the setup unfortunately.
Robby
Dirty Old Man
PostPosted: 18:07 - 24 Jan 2011    Post subject: Reply with quote
I'd go with master cyl failing in the middle too. When the brakes go like that it's almost always a master cylinder fault in some way.
PostPosted: 18:09 - 24 Jan 2011    Post subject: Reply with quote
Thinking about it I tend to agree.
Brakes feel like they do when you have a small leak in the system (except the pedal won't reach the floor), but it isn't using fluid.
weasley
PostPosted: 20:11 - 24 Jan 2011    Post subject: Reply with quote
Possible leak in the vacuum assist cylinder?
PostPosted: 20:15 - 24 Jan 2011    Post subject: Reply with quote
Vacuum leak would normally make the brakes harder rather than giving more travel. A fluid leak into the brake servo would result in fluid being used. The fluid level isn't going down which is the confusing bit.
Oddly just looked at another car of the same model and its brakes behave in the same way.
weasley
PostPosted: 22:03 - 24 Jan 2011    Post subject: Reply with quote
The reason I suggest the vacuum assist is that if you pump the brakes when the car is off, the pedal will go hard. Then put your foot on the brake and start the engine and the pedal will drop a little - sounds like the symptoms you describe is all!
PostPosted: 22:18 - 24 Jan 2011    Post subject: Reply with quote
With the engine running it produces vacuum which operates the servo. Would need more vacuum rather than a leak.
mad4it028
PostPosted: 22:33 - 24 Jan 2011    Post subject: Reply with quote
if it has drum brakes on the back re adjusting will bring pedel up but as its only creeping down ide sujest air in master cylinder if no leak but again if it has drums on rear the cylinder could be leaking dosnt have to be by much
mad4it028
PostPosted: 22:36 - 24 Jan 2011    Post subject: Reply with quote
oh yes best way in my opinion to pin point a brake pedel problem on a car is this
clamp all 4 flexi hoses then with engine started pump pedel if its nice and hard this rules out master cylinder
then remove 1 clamp pump if this hard that caliper or cylinder is good refit and do same to next one untill you find where it goes soft
once found should be easy to sort why its soft could just need bleeding
PostPosted: 22:49 - 24 Jan 2011    Post subject: Reply with quote
It has disks all round.
It doesn't feel like it needs bleeding. The brakes are not spongy. Stamp on them and the pedal stops rapidly. It just then slowly carries on going down.
mad4it028
PostPosted: 22:58 - 24 Jan 2011    Post subject: Reply with quote
clamp the flexis this will at least point you to the problem Thumbs Up
Raffles
PostPosted: 23:00 - 24 Jan 2011    Post subject: Reply with quote
+1
PostPosted: 23:19 - 24 Jan 2011    Post subject: Reply with quote
Trouble is that I can't think of any way that anything after the flexi hoses would allow the pedal to slowly descend except for a small fluid leak, but there has been no loss of fluid.
mad4it028
PostPosted: 00:38 - 25 Jan 2011    Post subject: Reply with quote
ok dont listen to me a few small bubbles will cause a pedal to creep but you wont try it thats fine
once youve exhausted everything eles maybe you will try and you will see what i mean
also a perished flexi can do it too as well as a master cylinder by clamping the flexi you can at least confirm or discount the master cylinder instead of guessing
mad4it028
PostPosted: 00:40 - 25 Jan 2011    Post subject: Reply with quote
Odie
PostPosted: 02:08 - 25 Jan 2011    Post subject: Reply with quote
Moisture in the system?
Shaft
PostPosted: 02:25 - 25 Jan 2011    Post subject: Reply with quote
You still haven't told us what the car is, that can make all the difference.
Teflon-Mike
tl;dr
PostPosted: 02:39 - 25 Jan 2011    Post subject: Reply with quote
I was just pondering that, and the idea its a citreon came into my head......
Shaft
PostPosted: 02:45 - 25 Jan 2011    Post subject: Reply with quote
Won't be a Citroen Mike, not if it's got hydropneumatic brakes; they don't have any brake pedal travel at all, even if the system is completely screwed!
bootsbiker
PostPosted: 05:38 - 25 Jan 2011    Post subject: Reply with quote
Is this right from the start of the journey or does it happen after a while. or heavy braking.. Does the car pull to 1 side when braking...??.
https://justfuckinggoogleit.com/
Nb
PostPosted: 06:54 - 25 Jan 2011    Post subject: Reply with quote
What car is it since alot of cars now do this, old vectras brake pedals sink like that but they stop just before the floor.
The last post was made 14 years, 340 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.95 - MySQL Queries: 13 - Page Size: 134.58 Kb
