lookin for a not so strict mot place near harrow for my bike
dna50
PostPosted: 21:50 - 27 Jan 2011    Post subject: lookin for a not so strict mot place near harrow for my bike Reply with quote
anyone know any mot stations in or near harrow area that arent too strict with bikes??????
hsaeed
Quote Me Happy
PostPosted: 21:53 - 27 Jan 2011    Post subject: Reply with quote
Maybe you could just sort out the bike?
stutterin' sam
PostPosted: 21:56 - 27 Jan 2011    Post subject: Re: lookin for a not so strict mot place near harrow for my Reply with quote
I took mine to a place like this for an MOT a day before the wheel fell off!!!
It is said that if you line up all the cars in the world end to end, some idiot on a sports bike would be stupid enough to try and pass them.
UKRedwing
PostPosted: 21:58 - 27 Jan 2011    Post subject: Reply with quote
Maybe he's just on about the exhaust as atm it's up the the examiners discretion whats too loud. Bloke at my local garage told me to grind the 'Competition use only' off it and he'd pass it.
If the Op is on about the bike not being up to scratch then I agree.. sort it out..
dna50
PostPosted: 22:08 - 27 Jan 2011    Post subject: Reply with quote
my exhaust is standard i might just put it through a mot and see what it needs. iv spent 200 on it so far im just not sure if it will fail on something minor. is a water leak a failure?
hsaeed
Raffles
PostPosted: 22:13 - 27 Jan 2011    Post subject: Re: lookin for a not so strict mot place near harrow for my Reply with quote
If anyone does know of such a place then they would be unwise to post details of it on a public forum Rolling Eyes
Livefast123
PostPosted: 22:13 - 27 Jan 2011    Post subject: Reply with quote
Not too strict on brakes, tyres, lights, chassis and steering, you know all those little things that keep you from meeting the tarmac or your maker Rolling Eyes
If your bike can't pass the MOT it shouldn't be on the road......simple Thumbs Up
Maybe you should spend the time looking for a dodgy MOT station buying a Haynes manual.
Current ride - Yamaha MT-07
dna50
PostPosted: 22:15 - 27 Jan 2011    Post subject: Reply with quote
thanks i think the only main problem is iv got a water leak is this a mot failure?
hsaeed
Livefast123
PostPosted: 22:24 - 27 Jan 2011    Post subject: Reply with quote
Water leak won't be a failure as long as the tester can test the vehicle without it overheating so he abandons the test.
Water leak on those is usually the water pump and you can get a cheap kit on ebay to fix it. Riding a water cooled ped with a leak is not a good idea.
dna50
PostPosted: 22:28 - 27 Jan 2011    Post subject: Reply with quote
what if the tester sees some drops of coolent leaking down will they fail it?
hsaeed
Livefast123
PostPosted: 22:33 - 27 Jan 2011    Post subject: Reply with quote
A water leak is not an MOT failure......it's not even tested on the MOT.
dna50
PostPosted: 22:38 - 27 Jan 2011    Post subject: Reply with quote
cheers thanks a lot iv even put a new cylinder head on it coz i thought it was cracked but the leaks still there when its cold i know its not a good idea riding it but i wont ride it i just need to get the mot done then ill sort the leak out after the bike hasnt been moted for the last 3years iv done so much work to get it on the road
hsaeed
Livefast123
PostPosted: 22:40 - 27 Jan 2011    Post subject: Reply with quote
Are you sure it's the cylinder head and not the water pump.........common prob with those engines.
dna50
PostPosted: 22:44 - 27 Jan 2011    Post subject: Reply with quote
yep its dripping from where it seals onto the bore
hsaeed
dna50
PostPosted: 22:50 - 27 Jan 2011    Post subject: Reply with quote
changed that iv spent 30pounds buying gaskets iv had enough of it i just wna get it mot'd then ill sort it out
hsaeed
dna50
PostPosted: 23:05 - 27 Jan 2011    Post subject: Reply with quote
ill take pic and upload it tomorrow. im not sure it even has a torque setting there just 10mm nuts that screw down the studs and hold the bore and cylinder head down. there done up tight
hsaeed
Livefast123
PostPosted: 23:19 - 27 Jan 2011    Post subject: Reply with quote
Head bolts always have torque settings Thumbs Up
It should say in the owners / workshop manual
Raffles
PostPosted: 23:44 - 27 Jan 2011    Post subject: Reply with quote
Why the big rush to get an MOT? Sort the leak out first.
There's no point having a bike tested if you are unable to use it.
ollieholt
PostPosted: 01:33 - 28 Jan 2011    Post subject: Reply with quote
'done up tight' isn't the grade you are aiming for with heads. A quick download of a workshop manual will tell you the correct torque to apply to each bolt and in which order sometimes.
Power is nothing without responsibility Thumbs Up
Laughing < This? Well this is just a day brightner.
SoND
PostPosted: 06:13 - 28 Jan 2011    Post subject: Reply with quote
Did you at least take your time to tighten them all gradually and evenly in a crossing pattern from the centre out?
This is really important, more so than the correct torque settings. If you didn't do it like that then it won't be flat and won't seal.
dna50
PostPosted: 22:54 - 28 Jan 2011    Post subject: Reply with quote
yes they where tightened in a cross pattern, does anyone know where i can download the tightening torques from iv looked on google but theres nothing there?
hsaeed
clancy
PostPosted: 23:01 - 28 Jan 2011    Post subject: Reply with quote
got a haynes manual ?
KLX 300r
The last post was made 15 years, 160 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.27 - MySQL Queries: 13 - Page Size: 125.75 Kb
