quick wireless question
dransy
PostPosted: 22:38 - 27 Jan 2011    Post subject: quick wireless question Reply with quote
Anyne got any ideas why my wireless cuts off when the house phone rings ?? Confused Confused
Flip
PostPosted: 22:41 - 27 Jan 2011    Post subject: Reply with quote
No.
Wireless phone next to wireless hubs can cause interference though.
Filter working properly?
That's all I have. Laughing
Frost
PostPosted: 22:48 - 27 Jan 2011    Post subject: Reply with quote
It does say that routers should be placed away from cordless phones on every one i've had.
panrider_uk
Do you have a filter on every phone socket that is in use?
Mark
Charlie
PostPosted: 12:11 - 28 Jan 2011    Post subject: Reply with quote
Is it the wireless network that cuts out or the internet? As in if you connected you computer to the router via an ethernet cable would it still be able to connect to the internet if the phone rang?
whitedevil
PostPosted: 12:49 - 28 Jan 2011    Post subject: Reply with quote
cordless phones and wireless routers both use 2.4GHz wavelength. try changing what channel your wireless is using and move the router away from the cordless phone.
Also make sure you have a working micro filter in each phone socket that is in use.
el_oso
PostPosted: 16:12 - 28 Jan 2011    Post subject: Reply with quote
+1
Duke 390
Car: Jeep Wrangler 4.0L
Kwaks
I'm not a fast rider
PostPosted: 19:43 - 28 Jan 2011    Post subject: Reply with quote
Calling your service provider is the easiest way, they can remotely change the channel the router is on.
www.cliqueycuntsmcc.co.uk
sickpup
Old Timer
PostPosted: 19:56 - 28 Jan 2011    Post subject: Reply with quote
Wouldn't it be easier to just go into the router and change the channel?
Frost
PostPosted: 22:23 - 28 Jan 2011    Post subject: Reply with quote
Each channel actually just shifts the frequency by 10MHz, which is fuck all really. So i doubt switching it will solve the problem on it's own. The router needs moving to a different room ideally.
panrider_uk
PostPosted: 03:04 - 29 Jan 2011    Post subject: Reply with quote
Changing channels can make a massive difference.
Mark
zx81
PostPosted: 11:33 - 29 Jan 2011    Post subject: Reply with quote
Hi all, new guy to the forums here.
Just noticed this post, I fix a lot of computers and I have seen this problem a few times, its to do with the way your phone socket is wired up.
if your phone rings, and you get disconnected when you pick-up it will reconnect within a minute or two however it will disconnect AGAIN when the phone is hung up, if you re using a filter then your Filter is faulty you will need a new one, you need a filter on every socket that a phone is connected to.
As for the wireless suggestions these are easy to rule out, just look at your wireless strength when you get disconnected, you will still be connected to the router, but the router is not connected to the internet (although it could be a different problem entirely).
that was quite a lot of words to say, change your filter. Thumbs Up
Colin Edwards
PostPosted: 11:35 - 29 Jan 2011    Post subject: Reply with quote
+1
+2
Colin Edwards
PostPosted: 11:37 - 29 Jan 2011    Post subject: Reply with quote
Calling your service provider is the easiest way, they can remotely change the channel the router is on.[/quote]
A bit over kill isn't it.. Cant you just connect to the admin interface and change the channel
CE
PostPosted: 12:32 - 29 Jan 2011    Post subject: Reply with quote
No they can't, I've changed the password Smile
The last post was made 15 years, 251 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.22 - MySQL Queries: 13 - Page Size: 84.73 Kb
