Throttle twist stuck.
B
PostPosted: 11:42 - 28 Jan 2011    Post subject: Throttle twist stuck. Reply with quote
The throttle twist grip (right hand grip) is stuck you can still twist the grip but it stays there,it does not go back to its place.
also when turning the motorcycle on it accelerates by it self.
the bike is GILERA DNA 50.
Gilera DNA 50.
PostPosted: 11:46 - 28 Jan 2011    Post subject: Reply with quote
You need to check the routing of the throttle cable.
DrDonnyBrago
PostPosted: 12:04 - 28 Jan 2011    Post subject: Re: Throttle twist stuck. Reply with quote
If your bike has two throttle cables, one could be broken.
If not, then as above check the routing and check the return spring mechanism that places tension on the throttle to make it close.
B
PostPosted: 21:16 - 28 Jan 2011    Post subject: Reply with quote
will be going to get the bike check tomorrow thank you guys.
Gilera DNA 50.
Dazbo666
PostPosted: 17:10 - 29 Jan 2011    Post subject: Re: Throttle twist stuck. Reply with quote
Had the exact same problem with my GPZ.
The clip retaining the end of the return cable was damaged
Word of the day : DILLIGAF
The Artist
PostPosted: 17:20 - 29 Jan 2011    Post subject: Reply with quote
Pros - Cruise control, auto choke when on sidestand.
Cons - Will fail MOT. Not as safe as a loose grip.
B
PostPosted: 22:28 - 29 Jan 2011    Post subject: Reply with quote
but can get it fixed right? has mot till sept
Gilera DNA 50.
The Artist
PostPosted: 19:02 - 30 Jan 2011    Post subject: Reply with quote
Yeh you can.
It will either be the cable is caught somewhere, maybe worn through or the rubber of the grip is rubbing on the switchgear.
The last post was made 15 years, 243 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.11 - MySQL Queries: 13 - Page Size: 56.62 Kb
