| P.addy |
 P.addy Red Rocket
 Posted: 12:23 - 29 Jan 2011 Post subject: GS125 Head...adjusting valves |
I have got my GX125 running All I need to do is adjust the valves...ive heard quieter tractors
How do you adjust these ones? It looks like a very odd way of doing it...the cylinder head has the valves but the actual top cover has the rockers..
How on earth do you adjust them. |
| serlant |
 serlant Brolly Dolly
| bacon |
 bacon World Chat Champion
| The Artist |
 The Artist Super Spammer
| Pete. |
 Pete. Super Spammer
 Posted: 19:28 - 29 Jan 2011 Post subject: |
YOu have to un-do the two big silver caps at front and rear then get a feeler gauge between the top of the valve stem and the bottom of the tappet adjuster.
https://img35.imageshack.us/img35/8286/img0259jq.jpg
When you remove the cap you'll see a bolt and locknut. Turn the engine by hand until you have the tappet loose on the base circle of the cam (where the gap is biggest), loosen the locknut, fit the feeler gauge and wind in the bolt until you feel it dragging, tighten the locknut then CHECK THE GAP because they like to tighten up when you lock them off with the nut.
If you're worried jump on it and ride it up to mine and I'll gladly do it for you. ____________________ a.k.a 'Geri'
| P.addy |
 P.addy Red Rocket
 Posted: 21:10 - 29 Jan 2011 Post subject: |
I'll have a go at doing it
The problem with riding it over... It's too noisy to start up! |
| Pete. |
 Pete. Super Spammer
 Posted: 21:40 - 29 Jan 2011 Post subject: |
If it's that noisy - check the top end is getting oil. ____________________ a.k.a 'Geri'
| fiery tupp |
 fiery tupp Trackday Trickster
 Posted: 21:51 - 29 Jan 2011 Post subject: |
Its the same as gz . Remove crankcase end cap - to turn over by hand , remove timing inspection cap ( on the top of flywheel cover) & valve caps . turn anticlockwise only a turn or two , find TDC on compression stroke / so both rocker arms are loose & adjust clearances .  ____________________ If you can't fix it with a hammer , use your head . |
The last post was made 15 years, 158 days ago. Instead of replying here, would creating a new thread be more useful? |
