GS125 Head...adjusting valves
PostPosted: 12:23 - 29 Jan 2011    Post subject: GS125 Head...adjusting valves Reply with quote
I have got my GX125 running Thumbs Up All I need to do is adjust the valves...ive heard quieter tractors Laughing
How do you adjust these ones? It looks like a very odd way of doing it...the cylinder head has the valves but the actual top cover has the rockers..
How on earth do you adjust them.
serlant
PostPosted: 13:38 - 29 Jan 2011    Post subject: Reply with quote
Sounds like bucket and shim? if thats the case measure all the clearances and compare, then get thinner or thicker shims depending on wether its over or under spec, and chances are you can swap a few around to get them in spec and not need to buy so many.
04 CBR1000RR, 1995 Husqvarna TE410, 1998 VTR1000(Sold), 1990 XJ600(sold), 1996 KH125(dead and sold)
bacon
PostPosted: 14:14 - 29 Jan 2011    Post subject: Re: GS125 Head...adjusting valves Reply with quote
are they not the usual tappets which you adjust with nuts? I cant imagine them putting shim under buckets on a gs125?
edit: like this
https://img.photobucket.com/albums/v218/mikejbry/beefcake/29122009446.jpg
The Artist
PostPosted: 17:12 - 29 Jan 2011    Post subject: Reply with quote
It is just tappets and locknuts on this engine.
Spin engine over until the valve tappet is at its maximum gap and you can move with your finger. Then loosen the locknut and the tappet and slide a feeler gauge underneath and set to the correct distance. Tighten everything up, done.
PostPosted: 19:28 - 29 Jan 2011    Post subject: Reply with quote
YOu have to un-do the two big silver caps at front and rear then get a feeler gauge between the top of the valve stem and the bottom of the tappet adjuster.
https://img35.imageshack.us/img35/8286/img0259jq.jpg
When you remove the cap you'll see a bolt and locknut. Turn the engine by hand until you have the tappet loose on the base circle of the cam (where the gap is biggest), loosen the locknut, fit the feeler gauge and wind in the bolt until you feel it dragging, tighten the locknut then CHECK THE GAP because they like to tighten up when you lock them off with the nut.
If you're worried jump on it and ride it up to mine and I'll gladly do it for you.
PostPosted: 21:10 - 29 Jan 2011    Post subject: Reply with quote
I'll have a go at doing it Smile
The problem with riding it over... It's too noisy to start up!
PostPosted: 21:40 - 29 Jan 2011    Post subject: Reply with quote
If it's that noisy - check the top end is getting oil.
fiery tupp
PostPosted: 21:51 - 29 Jan 2011    Post subject: Reply with quote
Its the same as gz . Remove crankcase end cap - to turn over by hand , remove timing inspection cap ( on the top of flywheel cover) & valve caps . turn anticlockwise only a turn or two , find TDC on compression stroke / so both rocker arms are loose & adjust clearances . Neutral
If you can't fix it with a hammer , use your head .
The last post was made 15 years, 158 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.49 - MySQL Queries: 13 - Page Size: 56.45 Kb
