Honda SP-1 LCD
Bofh5
PostPosted: 14:52 - 30 Jan 2011    Post subject: Honda SP-1 LCD Reply with quote
My LCD has stopped working and wondered if anyone knew if it had a reset of some kind ?
Its been working fine but shes been sat for a while so i decided to charge the battery overnight.
Today i turned the key and at first the display came on but the FI and Fuel light stayed on after i started the engine and the lcd was messed up.
Turned her off and tried again this time the display didnt even go through its usual startup routine.
Ive tried disconnecting the battery but didnt make any difference.
Any ideas ?
(L)users...Disk space is to good for them.
Bikes: Honda 50 / CB125-TDC / 93 CBR600 F2 (Stolen & Trashed) / 2001 SP-1 (Sold) / 95 CBR600 F3
salty21
PostPosted: 17:44 - 30 Jan 2011    Post subject: Reply with quote
my cbr used to do that.
It was a bad connection on the plug at the back of the clocks so it's worth checking that.
Have you tried giving it a technical tap yet? that used to get mine going temporarily sometimes.
PostPosted: 17:48 - 30 Jan 2011    Post subject: Reply with quote
Moisture of something hasn't kept into the connectors as the back of the clocks has it?
Give it a dose of WD40.
Since when did you get an SP1!
Bofh5
PostPosted: 18:36 - 30 Jan 2011    Post subject: Reply with quote
yep ive tried wiggling it and tapping but no good Sad
the neutral light and that work fine and the backlight is ok but no lcd or FI or fuel warning light.
i'll pm blackwolf and see if he has ever had this in his.
I got the SP last year Smile only ridden her a few times.....scary as hell Shocked
Noxious89123
PostPosted: 21:36 - 31 Jan 2011    Post subject: Reply with quote
Update your sig! Smile
The last post was made 15 years, 222 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.37 - MySQL Queries: 14 - Page Size: 45.09 Kb
