| jc20steve |
 jc20steve L Plate Warrior
 Posted: 18:17 - 30 Jan 2011 Post subject: honda nsr jc20 rc valve motor |
hi peeps
I recently brought a honda nsr 125 jc20 import took it for a ride the other day it felt gutless it wouldnt rev over 6000 rpm smoked alot compression is fine ect. so i checked the rc valve motor it wasnt turning atall stuck closed on the exhaust port
so my question is because all the jc20 parts are gettin hard to find will the fox eye rc valve parts fit
and if anyone dose have the proper jc20 parts for sale ie servo motor and the tv78 unit please contact me
all the best peeps steve  |
| st3v3 |
 st3v3 Super Spammer
| alan1966 |
 alan1966 L Plate Warrior
| alan1966 |
| alains |
 alains World Chat Champion
 Posted: 10:47 - 31 Jan 2011 Post subject: |
about the parts , you can exchange engine spares but not the RC/valves system including the controlers
to be sure about the electronics you should do first :
- unplug the servo-motor
- with multipliers catch the pulley and turn it as far as you can to set the valves in HI position (max openning)
- take a run and see how it goes (normally you should reach 11000 rpm in 4th gear)
if it's OK , now re-plug the servo-motor and dismount the cables from the pulley (living the valves on HI & remember where cables are set on the pulley)
download my file https://www.geneva-racing.ch/~alains/NSRtips.doc , look bottom page #10
start engine and observe the pulley while accelerating up to 8000 rpm . if the sequence is correct , your valves are stocked in the exhaust port and your engine needs de-coke with rings change (eventually piston or cylinder-piston kit)
if not , could be the CDI , RC/valves controler or the servo-motor
checking the servo-motor is easy
feed quickly (max 1s) from the battery between white & white/black and if it works reverse polarities
if OK both ways your servo-motor is OK
for the CDI & RC/valve controler it's quit impossible but very often loose contact on the red/white makes this problem
good luck on your quest (keep me inform) ____________________ the worst day fishing is better than the best day working |
| jc20steve |
| alains |
The last post was made 15 years, 221 days ago. Instead of replying here, would creating a new thread be more useful? |
