Disc cloning/ghosting software?
PostPosted: 19:24 - 31 Jan 2011    Post subject: Disc cloning/ghosting software? Reply with quote
I want to ghost a single drive, to fit a bigger drive in a laptop. Any suggestions on free software to perform this as a one-off?
panrider_uk
PostPosted: 19:41 - 31 Jan 2011    Post subject: Reply with quote
Clonezilla- linux based boot cd
Mark
Colin Edwards
PostPosted: 21:23 - 31 Jan 2011    Post subject: Reply with quote
Search for hirens CD.
Get a version 10 or before and use the ghost option in backup tools. (Ghost was removed in the later versions)
Its a bootable CD and strait forward to use.
Comes with many tools you might need one day or another..
https://www.hiren.info/pages/bootcd
CE
duhawkz
PostPosted: 16:39 - 01 Feb 2011    Post subject: Reply with quote
https://ping.windowsdream.com/
I have used ping before, its free and easy to use
MiztaZiggy
PostPosted: 18:38 - 01 Feb 2011    Post subject: Reply with quote
I have just done exactly the same thing. I read about clonezilla and a few other free programmes but in the end just did it with Windows backup and restore.
I had 2 250GB disks in RAID 0 and swapped to two newer 500GB disks in RAID 0.
Start by opening windows backup restore (assuming you are using Windows 7 here btw)
Click on create image and back up your existing disk to an external hard drive.
If you dont have an external hard drive, then you can install your new disk and partition it so that there is a partition the same size as the currently USED space on your existing disk.
Back up hard disk to this and when it asks you to create a recovery disk, do it, dont skip and assume you can use the Windows 7 DVD because although it looks the same, it doesnt work for some reason and asks for the recovery DVD (I tried).
Remove the old disk and then boot from the recovery DVD. Follow the very easy steps on the screen and it will find the backup and restore the drive image to your new disk.
When you boot back to windows, you will have 2 hard drives showing. Just go into computer management (control panel->admin tools->computer management->disk management) and delete the partition and extend the main partition to use up all the space.
If you put your old hard drive in there and have them both running at the same time, you will get some errors as they both have the same ID code or something, an option will pop up asking you if you want to use them both at the same time, just click yes and it should work fine. It did for me.
PostPosted: 01:23 - 02 Feb 2011    Post subject: Reply with quote
Thanks a lot. Used Clonezilla - couldn't be easier, burnt cd, booted from it, kept pressing enter Smile
The last post was made 15 years, 242 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.5 - MySQL Queries: 13 - Page Size: 48.97 Kb
