Stuterring CBR 600F
Straker
PostPosted: 21:19 - 30 Jan 2011    Post subject: Stuterring CBR 600F Reply with quote
Hi All,
My CBR600F has developed a stutter. Only happens when cold. Will stutter above 3k rpm for the first couple of miles then be ok. I assume this is a minor issue that could be solved with a service. Plugs? fuel line? carbs? Any ideas gratefully received. Apologies for my mechanical ignorance.
cheers
Straker
Current: CBR 900 RR3 (954 Blade)
Previous: CBR 600 FY (01),
09 Triumph Street Triple R (nicked), R6 (04), CBR 600 FX (00), GPZ 305 (lol)
Ichy
PostPosted: 22:09 - 30 Jan 2011    Post subject: Reply with quote
A service may well fix it but just be aware that it is also a sign of a failing coil. On the CBR FY each plug cap has a built in coil.
Straker
PostPosted: 14:55 - 31 Jan 2011    Post subject: Reply with quote
Thanks for the tip. Will definitely get that checked out.
UKRedwing
PostPosted: 16:33 - 31 Jan 2011    Post subject: Reply with quote
Does the FY have carb heaters? Or is it fuel injected? On the phone and cba to google. Because you've said it's only happening when it's cold I would say its carb icing assuming its carbed...
Ichy
PostPosted: 17:34 - 31 Jan 2011    Post subject: Reply with quote
Blaming carb icing is like blaming the Esso for the price of fuel. Generally carb icing is caused at high throttle opening due to the venturi effect rapidly cooling the air. It can't occur when the bike isn't moving. Now frozen carbs are a different thing altogether.
FY is carb by the way and they are heated by the cooling system.
A fair few people recommend a fuel additive, Pro FST, for better running during the winter. I never needed it so I've not tried it.
UKRedwing
PostPosted: 17:51 - 31 Jan 2011    Post subject: Reply with quote
Well I suggested that as the prpblem as my friend had a 1997 GSXR 600 SRAD that suffered terribly in the winter from carb icing, it was worst when slowing down and pulling away at roundabouts etc
Noxious89123
PostPosted: 21:30 - 31 Jan 2011    Post subject: Reply with quote
Marki wrote:
A fair few people recommend a fuel additive, FS365, for better running during the winter. I never needed it so I've not tried it.
You mean Pro FST! FS365 is the ScottOiler anti-corrosion spray.
Ichy
PostPosted: 21:50 - 31 Jan 2011    Post subject: Reply with quote
No I know what I meant, I don't make mistakes, ever. Errrr its like a ummm secret thing y'know?
(Nonchalantly walks away whistling while planning a shifty little edit)
tk338
PostPosted: 02:08 - 01 Feb 2011    Post subject: Reply with quote
I'm convinced my fy's problems with stuttering and powerloss, were fuel pump related... I'll link you too the thread when I get on a pc Smile
The last post was made 15 years, 224 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.8 - MySQL Queries: 13 - Page Size: 60.33 Kb
