| c_dug |
 c_dug Super Spammer
| truslack |
 truslack World Chat Champion
| c_dug |
 c_dug Super Spammer
 Posted: 13:32 - 02 Feb 2011 Post subject: |
Hadn't considered air flow
To be honest the place I have planned for it isn't much better in terms of air flow, although there is far more space around it so at least the heat can move. ____________________ I am a bellend, I am a man of constant sorrow, I am a gummy bear, I am a rock. |
| Bezzer |
 Bezzer World Chat Champion
| c_dug |
 c_dug Super Spammer
| chris-red |
 Posted: 14:48 - 02 Feb 2011 Post subject: |
Wire in a PC fan to it, some of them run on 12volts
Personally I wouldn't want something that would get hot against my Battery.
Something like this,
https://www.maplin.co.uk/brushless-12vdc-axial-fans-1806?c=so&u=strat15
you should be able to connect it from where you joined the reg/rec to the system.
How is it working anyway? ____________________ Well, you know what they say. If you want to save the world, you have to push a few old ladies down the stairs.
WANTED:- Fujinon (Fuji) M42 (Screw on) lenses, let me know if you have anything. |
| c_dug |
 c_dug Super Spammer
 Posted: 15:05 - 02 Feb 2011 Post subject: |
It's working perfectly  ____________________ I am a bellend, I am a man of constant sorrow, I am a gummy bear, I am a rock. |
| Casper |
 Casper World Chat Champion
| Howling TerrorOutOfOffice |
 Howling TerrorOutOfOffice Super Spammer
| Pete. |
 Pete. Super Spammer
 Posted: 16:31 - 02 Feb 2011 Post subject: |
Larger should mean cooler but it's only cooled by air circulation. I take it the battery is in a plastic tray? If so that won't help since the plastic won't conduct heat away too well. Best to move it to where there's some airflow. Is there no room in the side of the tailpiece? ____________________ a.k.a 'Geri'
| c_dug |
 c_dug Super Spammer
| Fortuna |
 Fortuna World Chat Champion
 Posted: 22:03 - 02 Feb 2011 Post subject: |
The new type reg/recs don't get that hot really as they are mosfet.
If it is getting hot though, you could do as stated above and wire a fan to it. It's actually not that uncommon a mod.
Or... place it where it should go and fix it using only one bolt the best you can. Cable tie the other hole to something.
Or.. Find a good place, drill new holes/make plates and get the soldering iron out.
| lihp |
 lihp World Chat Champion
| c_dug |
 c_dug Super Spammer
 Posted: 22:57 - 02 Feb 2011 Post subject: |
Yep mines a 600F and my connector also looked similar, although it was salvageable which made connecting the triumph one a whole lot easier
Not sure how hot the new one gets to be honest, how long would it take to heat up? ____________________ I am a bellend, I am a man of constant sorrow, I am a gummy bear, I am a rock. |
| lihp |
The last post was made 15 years, 265 days ago. Instead of replying here, would creating a new thread be more useful? |
