| vtr firestorm |
 vtr firestorm L Plate Warrior
 Posted: 19:02 - 04 Feb 2011 Post subject: clutch slave cylinder leak |
Hi could anybody help i noticed a little puddle of what a thought was petrol the last couple of days on my firestorm
Ive now had chance to look at it properly and there is fluid leaking out of the slave cylinder next to one of the bolts
Just wounded if it was just a case of taken the cylinder off and putting a new gasket on or would i have to drain all the fluid out before i took the cylinder off
thanks steve  ____________________ slim |
| finpos |
 finpos World Chat Champion
| vtr firestorm |
 Posted: 12:37 - 20 Feb 2011 Post subject: cannot bleed clutch |
hi again could anybody give me any advice please
i decided to strip the slave cylinder and put new seals in cleaned everything up put it all back together and i cannot get the clutch to work i cannot get the fluid to run through the bleeder kit fully it just trickles in
i was told i could use any fluid as long as it was dot 4 so i got some from a car shop so i dont know if this has anything to do with it  ____________________ slim |
 ..... Quote Me Happy
| stinkwheel |
 Posted: 13:14 - 20 Feb 2011 Post subject: |
Try bleeding it at the top banjo bolt on the master cylinder.
So pack the area round it with rags, pump three time and halfway through the third pump, crack the bolt open then closed. Hopefully you'll get a bubbling of air coming out. Keep at it, pump, pump, bleed, pump, pump, bleed until you are getting a squirt of fluid every time with no air, then go back to bleeding the slave cylinder.
Hydraulic fluid from a car shop should be fine. Dot 4 is the standard it's made to, one is pretty much the same as the other ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| vtr firestorm |
 Posted: 21:37 - 21 Feb 2011 Post subject: cheers lads |
thanks for the help lads tried stinkwheels method first to save me having to buy a syringe worked fine thanks joe sounded like a good idea aswell  ____________________ slim |
The last post was made 14 years, 344 days ago. Instead of replying here, would creating a new thread be more useful? |
