clutch slave cylinder leak
vtr firestorm
PostPosted: 19:02 - 04 Feb 2011    Post subject: clutch slave cylinder leak Reply with quote
Hi could anybody help i noticed a little puddle of what a thought was petrol the last couple of days on my firestorm
Ive now had chance to look at it properly and there is fluid leaking out of the slave cylinder next to one of the bolts
Just wounded if it was just a case of taken the cylinder off and putting a new gasket on or would i have to drain all the fluid out before i took the cylinder off
thanks steve Confused
slim
finpos
PostPosted: 19:50 - 04 Feb 2011    Post subject: Reply with quote
Most likely the hydraulic seal has gone, in which case the cylinder will have to come off and you'll need to drain (and refill, obv) the whole thing.
You'll probably need a new seal(s) and possibly a new piston which are all not madly cheap, and it's a bit of a job to re-build them right, so if you are not sure what you are doing just replace the whole cylinder with a new one if it's not too spendy.
Edit - P.S. wash the fluid of any painted surface that you'd like to remain painted.
f.
vtr firestorm
PostPosted: 12:37 - 20 Feb 2011    Post subject: cannot bleed clutch Reply with quote
hi again could anybody give me any advice please
i decided to strip the slave cylinder and put new seals in cleaned everything up put it all back together and i cannot get the clutch to work i cannot get the fluid to run through the bleeder kit fully it just trickles in
i was told i could use any fluid as long as it was dot 4 so i got some from a car shop so i dont know if this has anything to do with it Embarassed
slim
Quote Me Happy
PostPosted: 12:41 - 20 Feb 2011    Post subject: Reply with quote
When I changed the seals on my bike I reverse-bled the system using a syringe and tube to inject the fluid up through the bleed nipple up to the reservoir. Worked a treat.
PostPosted: 13:14 - 20 Feb 2011    Post subject: Reply with quote
Try bleeding it at the top banjo bolt on the master cylinder.
So pack the area round it with rags, pump three time and halfway through the third pump, crack the bolt open then closed. Hopefully you'll get a bubbling of air coming out. Keep at it, pump, pump, bleed, pump, pump, bleed until you are getting a squirt of fluid every time with no air, then go back to bleeding the slave cylinder.
Hydraulic fluid from a car shop should be fine. Dot 4 is the standard it's made to, one is pretty much the same as the other
vtr firestorm
PostPosted: 21:37 - 21 Feb 2011    Post subject: cheers lads Reply with quote
thanks for the help lads tried stinkwheels method first to save me having to buy a syringe worked fine thanks joe sounded like a good idea aswell Thumbs Up
slim
The last post was made 14 years, 343 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.11 - MySQL Queries: 13 - Page Size: 47.29 Kb
