Cg not starting
von1papen
PostPosted: 18:24 - 05 Feb 2011    Post subject: Cg not starting Reply with quote
Need to get her running again for tomorrow's 100 mile journey to Uni so its a tad worrying Sad
Started fine yesterday, seeing as she was cold I revved the accelerator to help her along but like normal once dying back to idle she just cut out. Fair enough give her another kick start.
Except now she won't do anything, thought I'd flooded the engine but after leaving her overnight plus charging the battery theres been no joy!
Afew weeks ago I'd fiddled with the idle screw to speed up the idling to stop her cutting out when slowing down behind traffic, however she started fine after doing this so I can't see whats changed.
The Spark plug is new and I've checked shes still sparking, also put a gallon of new petrol in!
Any ideas?
fiery tupp
PostPosted: 21:29 - 05 Feb 2011    Post subject: Reply with quote
Easy start or WD40 in the airbox might get it up & running , as it seems like you haven't time for diognosing fully the problem . And hope it sorts its self out with a run ? Neutral
If you can't fix it with a hammer , use your head .
cb1rocket
PostPosted: 21:46 - 05 Feb 2011    Post subject: Reply with quote
you haven't fiddled with the air screw by mistake?
von1papen
PostPosted: 22:00 - 05 Feb 2011    Post subject: Reply with quote
Shes a 1996 model, took apart the air filter and it was bolloxed, literally crumbling n smelt of petrol Confused
But anyways I replaced the air filter, will spray on some WD40 then!
I could well have done and by the looks of the spark plug the mixture is wayyy to rich, so I tightened the screw now to give a leaner mix, giving it ten minutes to unflood with petrol and hopefully with the new air filter she should start working!
Ps the new air filter is a homebase sponge because I didn't have any other choice Laughing
Worst comes to worst I'll open up the carb to check for dirt or a blockage but don't really want to because its dark and raining lmao
Will Update If anything works/changes!
cb1rocket
PostPosted: 22:13 - 05 Feb 2011    Post subject: Reply with quote
as rob said, put the mixture screw back to standard, usually 1 and half turns out. Remember the mixture screw is only the mixture control when the bike is idling! It has no effects when the throttle is opend up.
Your bike has been running rich if the air filter was blocked to buggery!
If your new to maintenance then I suggest reading the Honda Common service manual, it explains the basics of how each part works and general service tips
von1papen
PostPosted: 22:16 - 05 Feb 2011    Post subject: Reply with quote
Stuck the screw back to standard, put the sponge in and she LIVESSSSSSSSSSSSSSSSSSSS.
Thanks for the help guys!
cb1rocket
PostPosted: 22:24 - 05 Feb 2011    Post subject: Reply with quote
now give it a full service and treat it like a baby! good for the fix Thumbs Up
kingsknight
PostPosted: 20:22 - 07 Feb 2011    Post subject: Reply with quote
100 miles on a 96 CG. hardcore Smile Thumbs Up
TS50 (sold) NS125F (sold) NSR125R-K (write off after 2 crashes) CG125 (nicked) XR125L-3 (Sold )-: ) DR125SM '11 (sold yay) XL125V '12 (In love with this bike) XT600E '04 (fun on the dirt)
von1papen
PostPosted: 22:46 - 07 Feb 2011    Post subject: Reply with quote
I'll tell you now it was an interesting old time, took me 4 hours Laughing
Well over an hour was spent stalling at traffic lights, roundabouts were also amusing.... Bear in mind over here theres no CBT so I sort of just muddled along best I could Embarassed
cb1rocket
PostPosted: 23:10 - 07 Feb 2011    Post subject: Reply with quote
100?! try 300 in one day! Twisted Evil
von1papen
PostPosted: 23:37 - 07 Feb 2011    Post subject: Reply with quote
Oh just a question, not worth opening a new thread over.
Having a lot of problems moving off, most of it due to my bad clutch control, but should I be releasing it to more than half way before she starts moving with a little throttle?? (Then the tiny bit more than she needs and one kinda stalls again.
I know the cable has a bit of damage to it, I think some of the rubber sheath has been taped up and there could have been a bit of surface rust on the cable itself although its been awhile since I looked at it carefully tbh. But I do remember my friend who did much of the work on her saying it needed replacing at some point.
cb1rocket
PostPosted: 23:45 - 07 Feb 2011    Post subject: Reply with quote
the clutch cable should be smooth to operate, if its binding and being jerky then yes, your more likely to easily stall it.
Other hand is that the cable is just about ok, and your letting the clutch out too fast or not enough throttle
von1papen
PostPosted: 23:46 - 07 Feb 2011    Post subject: Reply with quote
Thought it was just me Laughing I'll order another anyway they're going for bugger all on ebay!
kingsknight
PostPosted: 23:02 - 08 Feb 2011    Post subject: Reply with quote
thats one of the best things about the CG, parts are so easy to come buy and they are cheap!
The last post was made 15 years, 64 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 1.53 - MySQL Queries: 13 - Page Size: 91.35 Kb
