| spetom |
 spetom Trackday Trickster
| Kickstart |
 Kickstart The Oracle
| stinkwheel |
 Posted: 10:29 - 07 Feb 2011 Post subject: |
Most stainless is weaker and more brittle than mild steel. Certainly unless you are going to be paying a lot of money for it.
If it was something not seeing much load such as bolts holding on plastics or a side cover, I'd use stainless.
If it is something structural, I'd use mild steel bolts stamped with 8,8 on top unless the original was a higher grade.
For super high load things like brake calliper bolts, I'd use original parts. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Vincent |
 Vincent Banned
| spetom |
| Kickstart |
 Posted: 17:48 - 07 Feb 2011 Post subject: |
It is difficult to know. Stainless steel can seize in place, but so can mild steel. Bigger problem is that stainless steel will likely be FAR harder to drill out than mild steel (from memory it work hardens with the heat from the drill). Pretty much any 2 dissimilar metals when put together will trigger corrosion.
I have used stainless steel bolts loads of times on things like carb float bowls and engine outer cases. But I do use copper slip (and you will also find things about copper causing corrosion but can't say I have ever had an issue with copper grease).
The last post was made 15 years, 232 days ago. Instead of replying here, would creating a new thread be more useful? |
