stood for 8 years
nightshaddow
PostPosted: 18:57 - 07 Feb 2011    Post subject: stood for 8 years Reply with quote
i am getting a bike that has been stood for at least 8 years (pick it up in the next week or so)
other than the obvious tyres bushes brake lines to check what should i check for in the engine
the bike is a 86 tzr 125 not sure on model though
Ingah
PostPosted: 19:01 - 07 Feb 2011    Post subject: Reply with quote
New oil and plugs?
Or are you talking about a non-runner/seized engine etc?
Either way, i'd expect all seals and rubbers to be less than healthy.
-- Ingah
PostPosted: 19:03 - 07 Feb 2011    Post subject: Reply with quote
Stood inside or outside? If outside and not covered up expect everything in the carb to be stuck solid. I bought one which was stood 7 years and everythign was siezed in the - even the float needles. I did get it all working through patiently soaking it all in thiiners or acetone (nail polish remover). Took me a whole weekend to fix up a bank of four carbs.
PostPosted: 19:09 - 07 Feb 2011    Post subject: Reply with quote
Difficult to know. Could have rusted through the petrol tank. Could be fine with little effort.
Tyres age and harden, but how much depends on how they have been stored (UV light seems to be bad for them). Wheel bearings often seem to fail not long after a long standing bike is brought back into use. Chain might be OK or might be a rusted mess depending on how it was before being stored. Forks might well have pitted. Etc.
Engine wise I would be tempted to whip off the carb and intake and dribble a bit of 2 stroke oil onto the bearings (mains and big end, doubt you can get at the little end) and turn the crank by hand a bit before reassembling it to start it up for the first time.
If it is a TZR125 of that age (think they only started to come into the UK in 1987) then it will be a steel frames ones with a drum rear brake and 16" front wheel.
nightshaddow
PostPosted: 19:18 - 07 Feb 2011    Post subject: Reply with quote
good place to start, not much sure on the history. i has been stored in a garage for around 8 years and its free, i am not shy on hard work and willing and able to take my time with it,
it is registered E plate though has the 3 spoke wheels and rear disc (suspect upgraded at some point in the past)
i will know more soon
PostPosted: 19:21 - 07 Feb 2011    Post subject: Reply with quote
An e plate would make it a 1987/88 model and it should have the drum rear. Standard colours would have been blue with light blue and yellow or white with red. Upgrading to the later wheels and disk rear brake would need quite a lot of changes
nightshaddow
PostPosted: 19:25 - 07 Feb 2011    Post subject: Reply with quote
i had the 89 f plate which had the drum rear about 9 years ago Thumbs Up looks like the bike has had a repaint (or at least the decals) it the same paint as my white and red one but the red is pink Embarassed (will definatly be changed)
when did they change from the early drum to the later disc
PostPosted: 19:34 - 07 Feb 2011    Post subject: Reply with quote
Not sure (and the autodata book lists the same wheels from 1987 to 1993). Going from an old catalog the brakes changed from 1990.
Jamie S
I'd be concerned about the crank seals, probably find they have perished being stood that long.
Jamie
nightshaddow
PostPosted: 19:39 - 07 Feb 2011    Post subject: Reply with quote
well a good place to start, after looking around on the net i see alot of good place's for some parts and not to expensive either,
can anyone recomend some good places for older bikes as i see some things are not listed like exhausts etc
Gazdaman
I did a trackday!!!
PostPosted: 19:45 - 07 Feb 2011    Post subject: Reply with quote
I'd probably get some oil down the bores and seeing if it turns over slowly before trying to fire it up.
Obviously change all fluids, probably tyres. Might find some of the seals have perished/hardened.
Depends what you want from the bike. If it's a project anyway then just strip it down from the word go. If you want it to ride, then I'd take medium precautions to make ure you don't kill it the first time you try to start it up and get a piston in the face.
Gaz
Teflon-Mike
tl;dr
PostPosted: 20:21 - 07 Feb 2011    Post subject: Reply with quote
Any bike, order of precedence of checks should be:-
- Sticky (tyres)
- Stoppie (Brakes)
- Steerie (Steering)
- Springie (Suspension)
Engines don't matter... all they do is shove you along.... before you get shoved along, you need to be sure you can STOP being shoved along, and if you are bing shoved along, you go in the direction you need to be going.
Tyres are tyres, going over stuff, not much you can do with them, apart from check they have air in them, and hold it. They either need replacing or they dont, but probably.
Brakes. Rubber seals and hoses perish, and while they may work 'OK'; if a bikes been stood, a little service can see early failure as they start being worked. So worth a throuogh inspaction amd possible overhaul.
Suspension.... likewise. at the very least, I'd flush the forks and refil with new oil, for ths simple reason that probably wasn't great the last time the bike worked, and best part aof a decade, its going to have gone off, and collected condensation, even if nothing has firred up, siezed or got clogged up. Back end pretty much teh same. Rear shock is sealed not a lot you can do with one apart from replace it. Maybe worth while. They tend to get worked hard, and go off, and layed up, again, could have leaked charge, settled out, and rubber bits likely to 'go' after some use. But swing-arm bushes and linkage, strip, inspect, and atthe very least regrease.
Thats the sticky, stopie and springie taken care off. Leaves head-race bearings in the steerie. Only real bit there is in teh steering! Again, strip, clean, inspect grease and re-assemble, though while in there for teh sake of £20 I'd fit new taper bearings.
THEN you can start thinking about the motor.
First up, dont start trying to start it in a hurry.
TZR is a powe-valve model, and teh first things to check are that the PV isn't siezed, then that the motor isn't siezed. 2ts will tend to stop with thier pistons at BDC and the exhaust port open. Condesnastion & corrosion, will see stuff gummed up, and in that area you have aluminium piston and barel, steel liner, iron rings, and often lots of electroytic corrosion.
So exhaust off, and have a look.
Inspect the exhaust, sat, they'll rust through.
Clean the PV and check the state of piston and rings through the port window, at the vert least. If not popping the top cleaning inspectng & re-assembling.
Change the gear-box oil, that too is probably old and murky with condensation. Flush and refil.
Likewise coolant. May be worth having a look at the water pump, making sure that hasn't firred up, and possibly the oil pump, make sure thats still delivering oil and not cloged or pipes perished.
Carb, remove, strip, clean. Almost certain to be gummed up, and you may want to have a look at the reed-valves too.
Teas-spoon of two-stroke oil down the inlet tract before you put the carb back on to put some lube in the crank-case for the bottom end. another down ths spark-plug hole to lube the bore,
And before you put a new plug in and start prodding trying to start it.....
Work it over for a while, get all that oil into the bearings and bore.
Then, new battery, you can try starting it... but, dont expect too much, and that excess of 2T in the crank-case and bore will take a while to burn off, and may coke the plug before it all goes....
So make sure you get a couple of plugs!
And don't try riding it or putting it under load. Give it a chance to warm up, and get to temperature, and go over the whole bike, looking for anything obviousely untoward, starting with teh exhaust, and any leaks, then the cooling system, and keep an eye on that auto-lube system.
Then you can see how it goes from there, and whether it runs cleanly, and iof theres carburation faults, PV problem, or if its rattling like a london taxi on shot main bearings, or coughing and stuttering from perished primary seals etc....
Thing is, ENGINE is the LAST of the critical systems to worry about, recommissioning an old bike.
Before you 'go' make sure you can stop, and steer!
Gazdaman
I did a trackday!!!
PostPosted: 20:24 - 07 Feb 2011    Post subject: Reply with quote
I'd say brakes are more important than tyres. I'd rather stop at a set of traffic lights with an under inflated set of tyres than be squashed by a lorry with a brand new BT45 on.
It's all academic anyway, because I'd say that checklist is only really important if you're intending on throwing a leg over it and riding it home.
Gaz
PostPosted: 20:33 - 07 Feb 2011    Post subject: Reply with quote
I'm in the same boat, about to start a '88 RXS100 that has been stood for nearly 5 years. Good luck!
PostPosted: 20:58 - 07 Feb 2011    Post subject: Reply with quote
Yes the UK bike came with no powervalve, but you could have one as an option.
Teflon-Mike
tl;dr
PostPosted: 21:24 - 07 Feb 2011    Post subject: Reply with quote
As I understood it, Original RD-LC had no power-valve in its barel.
Later MKII RD-LC with 16" front wheel, for other markets was sold as the RD125LC 'YPVS' with fully functioning PV in its pot, but for the UK, the 'MKII' got the non power valve barel.
The UK RD-LC MKIII, which I'm not even sure is an official designation, got the YPVS barel, with Power-Valve, but pegged in the closed position. And I thought it was that one, you could order YPVS controller and cables for to 'de-restrict' if you knew the part no's, no official 'kit' being offered.
When the TZR came along, I thought it had the full YPVS motor, with operational PV in it, but for UK restrictions, it had a different controler to open it at a different time, and a different linkage to limit how far it opened... and I thought that there WAS actually a dealer 'de-restriction' kit for it that would swap the limited travel linkage, and controller for the full-power versions, as well as contained the jets for a de-restricted motor, and possibly a couple of other 'bits'. But.... never been THAT into RD's & TZ's, and I know that the 'lore' surrounding them is incredibly erroneousness, and have come accross reports of fully operational PV RD-LC's, and pegged valve TZ's, that may have been official UK bikes or more likley ameteur attempts at de-restriction.
Bottom line, its a 20+ year old Power-Valve bike of dubiouse oragin & history, so its worth checking!
As are the frame & engine no's, given disc-brake conversion.....
May have any number of bits from a later 'crashed' (Or nicked!) TZR, or RD, or DT, or well, who knows with old learner bikes!
nightshaddow
PostPosted: 21:29 - 07 Feb 2011    Post subject: Reply with quote
The TZR doesn't have an operating powervalve in it's UK form (yes I know it can be made operational but no one ever bothered). For someone who makes long, detailed posts you're attention to detail is sadly lacking. Must try harder C-.
tbh i dont know for sure but it is an early tzr (e reg) and someone has taken the time and money to fit a disc rear wheel in its life, it would not surprise if it has a working pv on there also (my last one did)
i think mike was very informitive though the reason i said i about the engine over anything else is the rest is to be replaced or serviced and i know what to do with stood bikes its just 2 strokes being stood i have never done, and in that respect the engine is what will be my greatest concern
Beelzebob
PostPosted: 21:35 - 07 Feb 2011    Post subject: Reply with quote
BLUEX5 wrote:
For someone who makes long, detailed posts your attention to detail is sadly lacking.
When criticising attention to detail it's worth checking your grammar is accurate Thumbs Up
'09 YBR 125 -> '92 XJ600 S Diversion -> '99 Hornet 600
"Stronger than your average female lifeguard"
Teflon-Mike
tl;dr
PostPosted: 21:38 - 07 Feb 2011    Post subject: Reply with quote
Gaz
True, & its actually a training .. gaws, theres a word for it... illiteration'? Using words with the same starting letter and 'shape' to make them easy to remember....
Its the pre-ride check-over, and tyres are at the top, becouse you can look at them before actually touching the bike, and theres actually a legal requirement on the tread depth...
And, they are the 'key' item in the dynamics of everything else. They are your point contact with the road, they have to transmit breaking and turning forces as well as motice ones, so everything else sort of hinges on them....
Still holds doing mechanics, where, still 'key,' bikes dont work too well without any! And 'poor' tyres are better than 'no' brakes!
But old addage, tyres are the first thing to check, the last thing to replace...
Tacking an overhaul or renovation, you check the tyres, if they are dire, you note them for replacement, but they are the last thing you actually buy, becouse you dont need them till everything else is 'done', and if you find a stopper doing the rest of the job, may be a waste of money!
... which was why, when we went to get Snowie her 'Project-Bike' it was the very fucking first thing we bought, stopping at Wheel-House on the way home with the bike still on the back of the car....... Probably be bludy perished by the time this thing sees tarmac under its wheels!
PostPosted: 22:00 - 07 Feb 2011    Post subject: Reply with quote
UK ones had no power valve control at all. Just the valve sitting in the barrel locked in the low rev position and a blanking piece on one side rather than any connections for cables.
However there was a kit available to make them full power. Similarly the fairings weren't a standard item but a dealer fit option.
It was the very late RD125 (called mk3 or RDZ125) that used the power valve engine. Never heard of non UK mark 2s having a power valve engine in them.
The very late (and pretty much unrelated) UK models of TZR were different again.
PostPosted: 11:45 - 08 Feb 2011    Post subject: Reply with quote
BLUEX5 wrote:
No UK spec bike had an active powervalve when it left the dealer's showroom.
Fairly sure there was a full power kit officially available for those with full licenses and learners in Northern Ireland (no 12hp / 125 limit there but because of insurance on 250s full power 125s were fairly common).
The last post was made 15 years, 234 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 1.36 - MySQL Queries: 13 - Page Size: 146.79 Kb
