custom exhaust manafacturers
clancy
PostPosted: 19:17 - 11 Feb 2011    Post subject: custom exhaust manafacturers Reply with quote
can anyone recomend a custom exhaust manafacturer ? im looking to have a system made to have twin cans (high mounted). any help appreciated
KLX 300r
PostPosted: 20:15 - 11 Feb 2011    Post subject: Reply with quote
Mark Hill Performance or MHP.
Quite expensive, but the systems are hand made. Used on a few minitwin bikes, and plenty of superstockers.
https://200mhp.co.uk/default.aspx
https://www.facebook.com/search.php?q=mepal%20motopack&init=quick&tas=0.8366258918735354#!/group.php?gid=17685488988
clancy
PostPosted: 20:24 - 11 Feb 2011    Post subject: Reply with quote
thanks mate Thumbs Up
KLX 300r
Billing
PostPosted: 20:28 - 11 Feb 2011    Post subject: Reply with quote
MHP already do an SP1 style exhaust mate, jap4performance.com, scroll down a bit on the NC35 page Thumbs Up It ends up about £700, but is probably cheaper than having a custom one done
clancy
PostPosted: 20:41 - 11 Feb 2011    Post subject: Reply with quote
yeah i seen the one on jap4performance Thumbs Up thought id do some asking because my mate had 2 cans and the link pipes made for his hornet for £360.
only thing currently putting me off is, is it going to sound odd being that its now 2 cans instead of the one it was made for ? like will it ruin the sound/performance
cheers guys
KLX 300r
Billing
PostPosted: 20:46 - 11 Feb 2011    Post subject: Reply with quote
to answer your question
https://www.youtube.com/watch?v=vcfXId9VlVw
no, they sound just as good Very Happy that's the same as the system I have on my NC30, and it's rather loud Twisted Evil
clancy
PostPosted: 20:50 - 11 Feb 2011    Post subject: Reply with quote
sounds about the same as it does now Very Happy ah thats good then.
i have a quill can at the minute, so i could just get the pipes made and buy another quill can for the other side right ? save a bit of moneys.
got a pick of your vfr ?
KLX 300r
Billing
PostPosted: 20:56 - 11 Feb 2011    Post subject: Reply with quote
you could it's a case of finding a Quill can that looks the same, but with the badge on the other side, then getting the flanges welded on (unless of course you have a slip on, then it's simple)
The main problem will be that because you're splitting the airflow into 2, you won't need such wide diameter pipes, so first off you'll probably need new reducersmade up. It's loads easier to spend the money on the properly made system with the proper cans.
This is the project thread for my VFR, the third and second to last pages should show the exhaust
https://www.bikechatforums.com/viewtopic.php?t=202062
clancy
PostPosted: 20:59 - 11 Feb 2011    Post subject: Reply with quote
well the can i have is for left side obviously with the badge on the outside, and there standard ones have it on the right side. so i would only need to buy a new standard one i suppose?
yeah i see what you mean about not needing as bigger cans :/ how can i tell if i have a slip on can or not?
cheers ill have a look
KLX 300r
Digitalize
PostPosted: 21:05 - 11 Feb 2011    Post subject: Reply with quote
Just to say my system uses 2 normal size cans, the guys at PRP dyno'd the last hornet they made them for and found no power loss with them. I don't think it matters too much tbh
1998 CB600F Hornet
clancy
i like Very Happy where did you get yours from mate ?
KLX 300r
Billing
PostPosted: 21:06 - 11 Feb 2011    Post subject: Reply with quote
Look at where the can joins to the pipe, if you have a stock NC35 system it will have 3 bolts holding it on. It may, however, have been hacked/swapped for a cut NC30 system and will have what looks a bit like a jubilee clip holding it to the pipe.
Any more problems you can always PM me, I don't have all of the answers, but will help if possible
clancy
PostPosted: 21:10 - 11 Feb 2011    Post subject: Reply with quote
i have 3 bolts in a triangle shape holding the can on, so thats a slip on yeah ?
where did you get your twin system made billing? thanks for the help Thumbs Up
KLX 300r
Jenks
PostPosted: 21:11 - 11 Feb 2011    Post subject: Reply with quote
have a look for zorstek. they do some lovely stuff!
1978 MZ TS 250 1 Supa 5
1992 yamaha fzr1000 exup
1998 aprilia af1 sintesi
Billing
PostPosted: 21:22 - 11 Feb 2011    Post subject: Reply with quote
nope, you got a bolt on mate, standard NC35 system.
Mine was bought from Japan, made by TSR Thumbs Up Keep an eye on Yahoo auctions japan for one, they don't come up very often, and don't expect much change from £500 for a used one
Digitalize
No, thats bolt on, Slip on is what it says on the tin, slips on, sometimes held by springs etc.
1998 CB600F Hornet
The last post was made 15 years, 279 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.08 Sec - Server Load: 0.34 - MySQL Queries: 13 - Page Size: 90.94 Kb
