Sump bolt leaking after fitting insert
Auzfest
PostPosted: 20:32 - 12 Feb 2011    Post subject: Sump bolt leaking after fitting insert Reply with quote
Just had insert fitted to sump but it is still leaking , iv noticed the garage fitted a copper washer instead of a crush washer though. Is this likely to be the cause of the leak?
Paxovasa
PostPosted: 20:35 - 12 Feb 2011    Post subject: Reply with quote
Sound like it is not set to the right Torque (under done)
Minty
PostPosted: 20:45 - 12 Feb 2011    Post subject: Reply with quote
Insert? Is that a helicoil? Was it threaded?
My fingers smell of your mum.
Auzfest
PostPosted: 20:59 - 12 Feb 2011    Post subject: Reply with quote
Yup similar to the helicoil , was threaded as a result of overtightening on an oil change. It leaked less when threaded with the old crush washer on but obviously the nut would't tighten without the thread so fitted an insert and replaced crush washer with a copper washer. Im assuming the copper washer doesn't make a good enough seal
Paxovasa
PostPosted: 21:02 - 12 Feb 2011    Post subject: Reply with quote
Or you got the wrong size insert.
Minty
PostPosted: 21:04 - 12 Feb 2011    Post subject: Reply with quote
Back to the garage then fella!
MaybeGuy
PostPosted: 21:10 - 12 Feb 2011    Post subject: Reply with quote
this.
you asked them to fix it, they didnt. so take it back and tell them to do it properly. do not pay them
Auzfest
PostPosted: 21:59 - 12 Feb 2011    Post subject: Reply with quote
mattsprattuk wrote:
this.
Straight back in on monday morning , bikes been in garage all week so i expected it to be sorted
PostPosted: 23:54 - 12 Feb 2011    Post subject: Reply with quote
The insert/thread does just one job, it's there for the sump plug to screw into. It's not in any way designed to be oil-tight as it's a parallel thread, so if it ever is that's just lucky.
The sealing surfaces are the underside of the bolt head, and the face of the boss on the sump in which the thread is cut. The copper washer is what is supposed to seal this joint as it deforms to fill any gaps or roughness.
If the joint is leaking, it's because either the copper washer is to thick or hard for it to deform enough to do it's job. To fix it, you (or they) have a number of choices:
Improve the surfaces the washer is sealing. Quite possibly there is a raised burr from fitting the insert.
Use a washer of a softer material like plastic
Use a thinner washer, that will deform more easily
Anneal the washer you have, to make it softer.
Ed Case
PostPosted: 00:19 - 13 Feb 2011    Post subject: Reply with quote
At a 'push' wrap some PTFE tape around the thread before screwing the plug in.
MaybeGuy
PostPosted: 00:27 - 13 Feb 2011    Post subject: Reply with quote
dont touch it. Otherwise theyll just tell you to do one for tampering
PostPosted: 19:51 - 13 Feb 2011    Post subject: Reply with quote
Yup, get back in and watch what they do. If I were the kind of dodgy garage that had already sent a "fixed" sump out with a leak, then I'd just back out the plug half a turn, slap some gasket sealant around it, do it up over-tight and hope that it holds for long enough for you to give up and sod off. Or I might have Borstal Baz drain the oil into some manky can full of crud and metal shavings, put a plastic washer on the plug and pour the contaminated oil straight back in.
You paid for a fixed sump and clean oil, you should have a fixed sump and clean oil.
Auzfest
PostPosted: 23:33 - 14 Feb 2011    Post subject: Reply with quote
Been riding the bike since discovering the bolt was still leaking as it is only a few drips a day and i have kept my eye on oil level but, i noticed after a days riding a weird hissing sound coming from the engine after turning of ignition and immediatly thought to myself "shit i that sounds like oil spraying out of the sump" but there was no indication of extra leakage, any idea what the hissing could be guys im guessing it has to be related to the leak like mayby it was pressure build up in engine venting through the leak ?
The last post was made 15 years, 138 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.08 - MySQL Queries: 13 - Page Size: 78.05 Kb
