.bat file to change Windows registry
Colin Edwards
PostPosted: 21:25 - 12 Feb 2011    Post subject: .bat file to change Windows registry Reply with quote
We are migrating from Novell GroupWise to Microsoft Outlook
I have created the packages to remove GroupWise and install Outlook and all works well.
The problem I have is that I can't remove the default mail profile from the client machines and this stops Outlook opening.
I need to do this with a LANDesk run batch file that imports a reg key and I have tried the following:
Copy to local machines:
@echo off
md c:\profilereg
xcopy /s \\sqlsut02\Packages\Office_2007\Outlook_Deployment\profilereg c:\profilereg
c:\profilereg\novellreg.bat
exit
To run the reg key install:
@echo off
regedit /s c:\profilereg\novellprofiledel.reg
exit
The reg keys:
[-HKEY_CURRENT_USER\Software\Microsoft\Windows NT\CurrentVersion\Windows Messaging Subsystem\Profiles]
"DefaultProfile"="Novell Default Settings"
[-HKEY_USERS\S-1-5-21-2720991719-3395378957-1752411362-9057\Software\Microsoft\Windows NT\CurrentVersion\Windows Messaging Subsystem\Profiles]"Novell Default Settings"
So the files all copy over and can be run from the machines manually but when done by deployment it doesn't import the reg changes
Am I doing something wrong? Can you suggest a better way?
Thanks for the help in advance
CE
TomCB
PostPosted: 22:22 - 12 Feb 2011    Post subject: Reply with quote
would this be any help? apparently reg.exe is a cmd line version of regedit
Faldo: "Classic BCF. A thread about sky diving is NSFW on post #2."
Colin Edwards
PostPosted: 22:59 - 12 Feb 2011    Post subject: Reply with quote
I tried this mate...
To be honest running all the things I tried manually worked..
Just seems when deployed with LANDesk or any another deployment it stops working...
Also when I removed the default profile it worked for that user but any other uses that logged on had the novel profile still...
Any more ideas?
CE
Frost
PostPosted: 23:05 - 12 Feb 2011    Post subject: Reply with quote
i think a .nfo file is a windows registry file.
Colin Edwards
PostPosted: 23:14 - 12 Feb 2011    Post subject: Reply with quote
Sorry dont understand?
CE
herulach
PostPosted: 00:13 - 13 Feb 2011    Post subject: Reply with quote
Is your packaging software running as it's own user? If so thats why the current user tag isn't working.
Are you sure the second one is correct? You've no dataitem in it.
YBR 125>FZS600
panrider_uk
PostPosted: 01:32 - 13 Feb 2011    Post subject: Reply with quote
Could you execute a vbscript file that makes the relevant registry changes?
Mark
Colin Edwards
PostPosted: 10:18 - 13 Feb 2011    Post subject: Reply with quote
Mark
If i could write VB then yes Smile
CE
b0ss
PostPosted: 23:00 - 13 Feb 2011    Post subject: Reply with quote
Try: -
reg import c:\profilereg\novellprofiledel.reg
If you're still having problems I can knock up a vb script for you.
b0ss
PostPosted: 23:15 - 13 Feb 2011    Post subject: Reply with quote
Sorry seen you tried reg import sounds like a permissions error. I don't use Landesk. This may help - https://community.landesk.com/support/docs/DOC-2417
Colin Edwards
PostPosted: 23:24 - 13 Feb 2011    Post subject: Reply with quote
yeah tried all that and even posted on the community forum..
Need to try the VB option I feel..
Thanks for the help though..
CE
b0ss
PostPosted: 11:00 - 14 Feb 2011    Post subject: Reply with quote
When I get into work later I'll knock a vbscript for you.
UrbanRacer
PostPosted: 11:36 - 14 Feb 2011    Post subject: Reply with quote
Do you use Zenworks? you can push out registry changes with ease using it.
Davo
Davo To The Rescue!
PostPosted: 12:10 - 14 Feb 2011    Post subject: Re: .bat file to change Windows registry Reply with quote
Colin Edwards wrote:
The reg keys:
I may be wrong but Isn't that the key for a specific user?
Would it not be bettter to change the S-1-5-21-2720991719... key to HKEY_CURRENT_USER? (which should then be the current user logged in)
Also, have you tried running each step of your batch file manually on a machine through the command prompt (as I don't see a command to copy the .reg file to the desktop machine)
Colin Edwards
PostPosted: 14:00 - 14 Feb 2011    Post subject: Reply with quote
It is now all sorted.
panrider_uk created me a vb script to try but I still had issues
Then it came to me. Rather than delete the old Novell profile I could repackage the Outlook client to force a new Outlook profile..
Wanst thinking the end of last week.
Thanks to you all that gave advice and tried to help
Appreciated
CE
Colin Edwards
PostPosted: 14:01 - 14 Feb 2011    Post subject: Reply with quote
Just got rid of it for LANDesk
CE
UrbanRacer
PostPosted: 01:05 - 15 Feb 2011    Post subject: Reply with quote
CE
I think that might be a step backwards, ZCM 11 is very VERY good.
Colin Edwards
PostPosted: 13:49 - 15 Feb 2011    Post subject: Reply with quote
Not disagreeing...
We are removing everything Novell
Colin
UrbanRacer
PostPosted: 13:58 - 15 Feb 2011    Post subject: Reply with quote
Not disagreeing...
Colin
I understand mate, TBH its the first time i have been impressed with a Novell product Laughing
panrider_uk
PostPosted: 15:47 - 15 Feb 2011    Post subject: Reply with quote
Well MS Exchange is fairly good but Windows Server is still playing catchup with Novell 4.1 IMO
Mark
The last post was made 15 years, 233 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.64 - MySQL Queries: 13 - Page Size: 106.53 Kb
