| von1papen |
 von1papen Spanner Monkey
 Posted: 19:18 - 14 Feb 2011 Post subject: My CG has died! |
Running fine this morning, took her 2 miles down the road to uni, parked up everything normal nothing to worry about! On to class I go...
And about 2 hours later come back to find..... she won't start, at all, spark plug is working, I walked to the petrol station to get more fuel, thats fine too....
Spent the past hour and a half taking things apart including having a look in the carb, plenty of petrol there so it isn't blocked by any means I wouldn't have thought.
She would turn over for afew seconds when bump started in second but only for a few, tried and tried again and she did get abit better but darkness was upon us and now my bike is stranded several miles down the road in a nice person's driveway
So if the fuel is running through fine, spark plug is fine, and there's plenty of fuel, what on earth could it be?
First time I'am actually fully bricking it about my bike  |
| Howling TerrorOutOfOffice |
 Howling TerrorOutOfOffice Super Spammer
| von1papen |
 Posted: 19:44 - 14 Feb 2011 Post subject: |
I don't see where it could have came from, shes been running fine for weeks now and nothing has changed, although she was running fairly low on petrol! And I could have sworn I saw some black dirt shizzle in the inline filter.
When I get her back, hopefully tomorrow (2 miles of uphill wheeling, can't wait) I'll take a better look.
Ps whilst taking off the carb I loosened up the accelerator cable, re tightened it up fully n now it feels like the handle is connected to nothing it literally moves back n forth with no effort. What have I buggered up in this end?
Kick start was also kicking back abit when I put it all back to together.
I've made it all horribly worse haven't I  |
| N cee thirty |
 N cee thirty Banned
| jemdna |
 jemdna Nova Slayer
| von1papen |
| N cee thirty |
 N cee thirty Banned
| von1papen |
| cb1rocket |
 cb1rocket World Chat Champion
| gager5000 |
 gager5000 Renault 5 Driver
| flumpy7 |
 flumpy7 Could Be A Chat Bot
| dextersaurus |
 dextersaurus World Chat Champion
| von1papen |
| fiery tupp |
 fiery tupp Trackday Trickster
| N cee thirty |
 N cee thirty Banned
 Posted: 00:27 - 15 Feb 2011 Post subject: |
https://i825.photobucket.com/albums/zz176/robyarr/DSC00769.jpg
lol heres one i made earlier,put it in and look through the airbox end to make sure its gone all the way in ____________________ '00 Aprilia RS50 > '92 Honda CG > '99 Yamaha Fazer > '91 Yamaha RXS > '79 Suzuki X5 > 01' Honda Cg > 07' Honda Cg > 82' Kawasaki Z200 > suzuki gsxr 400 gk73a > honda vfr 400 NC30 Mod 2 Passed 09/06/2011
Jewlio Iglesias wrote: I actually did vote BNP once |
| von1papen |
| Pete. |
 Pete. Super Spammer
 Posted: 00:34 - 15 Feb 2011 Post subject: |
From this and your previous posts it sounds like the carb does need a good clean-out. Poor starting and no idle can also be low compression but as you only have 13k miles on it that shouldn't be the case.
Turning up the idle can cause your bike to be hard to start, as it reduces vacuum between the carb and engine. Try turning the idle screw back down and starting it on choke.
The CG is very frgal on petrol so if there's any fuelling issues it will be sensetive to them. I suggest getting it home and stripping the bowl off the carb, inspect the inside. Take photos. ____________________ a.k.a 'Geri'
| Ditto |
 Ditto Nearly there...
| kingsknight |
 kingsknight World Chat Champion
| von1papen |
 Posted: 19:19 - 15 Feb 2011 Post subject: |
Up and running! Pushed her 2 miles back home, stripped carb, wee pump off the carb and cleaned the jets n valves.
Cleaned spark plug and flushed the inline filter, also replaced the clutch cable which has made clutch control sooooooo much easier.
| N cee thirty |
 N cee thirty Banned
| von1papen |
| jemdna |
 jemdna Nova Slayer
 Posted: 19:42 - 15 Feb 2011 Post subject: |
I'm glad my vague idea of your carb might be dirty because of low fuel worked
Bry |
| cb1rocket |
 Posted: 22:18 - 15 Feb 2011 Post subject: |
just keep a good filter on there and your be fine, glad its sorted thou  |
The last post was made 15 years, 254 days ago. Instead of replying here, would creating a new thread be more useful? |
