Steering issue.
Bike Chat Forums Index -> The Workshop via Highlights
PostPosted: 16:16 - 15 Feb 2011    Post subject: Steering issue. Reply with quote
On my little RXS I am doing up there is a possible issue with the steering. There is not notchyness or anything to untoward, just that if you are turning the steering kind of falls inwards faster once it gets to a certain point. This happens both on the bike and with the wheel off the ground, once the steering goes past about 1/2 way it falls very quickly to full lock.
1. How to fix it? Is it the head bearings?
2. Is it an MOT failure?
Bezzer
PostPosted: 16:49 - 15 Feb 2011    Post subject: Reply with quote
If theres no notchiness and no play at all when you rock the forks back and forward on and off the ground then it won't fail an MOT. You could tighten the head bearings up a touch if you want, manual will give you the right method for your particular forks. They will fall a bit quicker as you turn them and go past the balance point.
DrDonnyBrago
PostPosted: 16:56 - 15 Feb 2011    Post subject: Reply with quote
If you are really heavy the front can go too light and will feel like it steers too quick. Same happened when I went pillion on my bros cb250.
PostPosted: 19:48 - 15 Feb 2011    Post subject: Reply with quote
The fact it happens with wheel off the ground would seem normal, all my bikes do so.. But the Daytona had a 16psi front tyre and was "flopping" into corners.
Popped 32psi in there and it was fine... take it your pressures are good?
PostPosted: 19:56 - 15 Feb 2011    Post subject: Reply with quote
Maybe it's me then, my other bikes do get quicker the more you turn but if you lift the front the sterring will turn one one and with hit full lock with a crash at a fair rate of knots.
27cows
PostPosted: 20:37 - 15 Feb 2011    Post subject: Reply with quote
Caused by there being less resistance in the cables when turning in one direction, I think. Depends on the routing. Mine does it to the right. More so since I removed the tacho cable when it snapped a while ago.
The last post was made 15 years, 254 days ago. Instead of replying here, would creating a new thread be more useful?
Post new topic   Reply to topic    Bike Chat Forums Index -> The Workshop via Highlights All times are GMT + 1 Hour
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.46 - MySQL Queries: 13 - Page Size: 51.58 Kb
