front sprocket!
andyboy359
PostPosted: 11:31 - 16 Feb 2011    Post subject: front sprocket! Reply with quote
Hello I have an aprilia rs 50cc 2007, and i need a new front sprocket, its a 13 tooth and i have heard if i put a 14tooth on it will go faster.
Questions is this true?
and if so how much more speed do i get??
It use to go about 55mph now i can red line it and a push it will do 50.... the sprocket i have atm has 3 teeth missing.
Thanks Andrew
PostPosted: 11:33 - 16 Feb 2011    Post subject: Reply with quote
Why not buy both and compare the performance? They aren't exactly expensive to buy.
andyboy359
PostPosted: 11:35 - 16 Feb 2011    Post subject: Reply with quote
but then what to do with the slower one Laughing Very Happy
PostPosted: 11:43 - 16 Feb 2011    Post subject: Reply with quote
Save it for when the engine is knackered and can't pull up hill.
andyboy359
PostPosted: 12:04 - 16 Feb 2011    Post subject: Reply with quote
what you mean when its Knackered??? Very Happy
PostPosted: 12:21 - 16 Feb 2011    Post subject: Reply with quote
Exactly that: when - not if!
skatefreak
PostPosted: 12:34 - 16 Feb 2011    Post subject: Reply with quote
Ragging a small engine at the redline all the time will knacker it... as in it will need rebuilding sooner rather than later...
Putting a smaller sprocket on there will make the bike accelerate faster but have a lower top end speed.
A bigger sprocket it will accelerate slower but give a higher top end speed...
Its a trade off between acceleration and top speed...
-Jvr
andyboy359
PostPosted: 00:23 - 19 Feb 2011    Post subject: Reply with quote
but iv been told its the back sproket that does all the top speed and that is that rite?? :S
Paxovasa
PostPosted: 00:30 - 19 Feb 2011    Post subject: Reply with quote
Have you never ridden a push bike with gears?
Changing either sprocket will affect the speed / acceleration.
Smaller rear sprocket = Better top speed, but slower acceleration.
Bigger rear sprocket = Better acceleration, but lower top speed.
Smaller front sprocket = Better acceleration, but lower top speed.
Bigger front sprocket = Better top speed, but slower acceleration.
Personally I would leave it standard.
andyboy359
PostPosted: 00:31 - 19 Feb 2011    Post subject: Reply with quote
so how much faster would 1 tooth do on a 50?? about 5mph?? Very Happy Laughing
totalllama82
PostPosted: 00:39 - 19 Feb 2011    Post subject: Reply with quote
Yes, or there abouts. Experiment as the sprockets are quite cheap. I'd advise changing your sprocket (both front, back and the chain) asap if its missing teeth as its likely to be badly worn and have affected the whole drive train.
Check your chain is not too tight, that the back wheel is aligned correctly also and that the chain is lubed properly Smile
Gone: Haotian HT125-8 / Yamaha YZF 600R Thundercat / Kawasaki ZX9R C2
Current: Kawasaki ZZR 1400 A7F
HD
PostPosted: 00:41 - 19 Feb 2011    Post subject: Reply with quote
Thats what it did to mine! The bike rides a lot smoother so the power is not as snappy but i dont like it like that. Preferred it before. It did 45 before and 50 at a push without blowing it up but will do 55 now screaming so I may go up again... Thinking
It is 14:53 at the moment if that helps?
andyboy359
PostPosted: 00:44 - 19 Feb 2011    Post subject: Reply with quote
so i got this bike till like aug so should i put a 14 tooth on it and know that it should be ok or stay with a 13 tooth?? Smile
Frost
PostPosted: 00:52 - 19 Feb 2011    Post subject: Reply with quote
A 14 will make the top speed higher, but make it accelerate slower, so it might not be able to pull the gear gearing, in effect lowering it's actual top speed. I'd stick with a 13 personally.
andyboy359
PostPosted: 00:56 - 19 Feb 2011    Post subject: Reply with quote
yh i think a 13 tooth will just be best tbh haha atleast i know was the sprokets do bigger and smaller front and back Very Happy Thank you every one Smile
HD
PostPosted: 01:06 - 19 Feb 2011    Post subject: Reply with quote
Yeah but you then have to change the chain if you go too far. And your bike may not be able to pull much higher speeds...
totalllama82
PostPosted: 11:47 - 19 Feb 2011    Post subject: Reply with quote
It really depends on where you ride. On my 125 I used to have to travel on a NSL dual carriageway and with a 15T sprocket it would not go near 60mph. Swapping to the 17T sprocket allowed it to touch 70mph at the red line (all be it going down a steep hill with the wind behind me).
If you need top speed, make the size change. If the top speed is acceptable, leave it as it is.
Note that changing to a larger sprocket may require a slightly longer chain!
The last post was made 15 years, 136 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 3.27 - MySQL Queries: 13 - Page Size: 98.98 Kb
