no drive
damongrimshaw
PostPosted: 00:02 - 17 Feb 2011    Post subject: no drive Reply with quote
My bike has no drive until the engine oils warm then it slips massively, I put new clutch plates in today and its still no good, when the engine oils cold there's a really numb feeling in the lever and when its warmed up it feels normal. When I first start it I can let the clutch out in first and nothing happens at all
Wanted: zx6r J1 fairings cash waiting
ian789
PostPosted: 00:04 - 17 Feb 2011    Post subject: Reply with quote
Which bike? Brick Wall
Robby
Dirty Old Man
PostPosted: 00:10 - 17 Feb 2011    Post subject: Reply with quote
I'd go with knackered clutch springs and/or a severely notched basket.
damongrimshaw
PostPosted: 00:16 - 17 Feb 2011    Post subject: Reply with quote
Its a lifan gy6 trailblazer I will try the springs as there fairly in expensive I checked the basket for wear when I changed the clutch is there anyway of testing the springs?
Robby
Dirty Old Man
PostPosted: 00:20 - 17 Feb 2011    Post subject: Reply with quote
Of course, before getting into all that I was assuming that you've made sure the clutch cable is correctly adjusted at the clutch end and level end.
If there's a Haynes manual it should give you some measurements for the springs. I wouldn't get lifan ones though, EBC should do springs if they need doing.
Of course, it is a lifan, so any diagnosis comes with a very large degree of uncertainty. They're so monumentally shit that problems no-one has seen for 40 years can rear their ugly heads. Usual advice, try to get rid of it asap.
damongrimshaw
PostPosted: 00:29 - 17 Feb 2011    Post subject: Reply with quote
Well you can knock it into gear and push it forward and it rolls like its in neutral, I tried the same thing with the clutch cable backed right off just to make sure and it still just rolled forward like it was in neutral
Billing
PostPosted: 01:36 - 17 Feb 2011    Post subject: Reply with quote
does the engine turn over if you put it in gear and roll it forwards with the engine off?
damongrimshaw
PostPosted: 08:56 - 17 Feb 2011    Post subject: Reply with quote
No it doesn't turn the engine over until the engines warmed up then it does
PostPosted: 12:03 - 17 Feb 2011    Post subject: Reply with quote
I don't know the bike at all, but on many bikes there is an adjuster for the clutch as well as for the cable (normally bigger bikes though). Quite easy with these to land up with the clutch adjusted to be slipping all the time.
PostPosted: 12:24 - 17 Feb 2011    Post subject: Reply with quote
Is there any feel on the clutch lever?
damongrimshaw
PostPosted: 14:04 - 17 Feb 2011    Post subject: Reply with quote
Thanks for the help guys, it was the clutch arm that was sticking so It working a treat now
The last post was made 15 years, 144 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 2.09 - MySQL Queries: 13 - Page Size: 66.04 Kb
