Laptop randomly turning off
panrider_uk
PostPosted: 10:08 - 18 Feb 2011    Post subject: Reply with quote
Sounds like its overheating.
Give the fans/heatsink a blast of air.
Mark
UnknownStuntm...
PostPosted: 12:00 - 18 Feb 2011    Post subject: Reply with quote
Laptops tend to be susceptible to a build up of hair, dust, grease, manmilk and all sorts of gunk. If I were you, open it up and look at the heatsink. There will most likely be a moustache around one side of it. Peel it off and as above, give it a blast of air.
Getting in most laptops is pretty easy - just Google "disassemble Acer Porn-lap-2000" or whatever model yours is. Most times you get in by a small cover running along the top of the keyboard, then take the keyboard out, then you can see the heatsink and fan unit.
huskie69
PostPosted: 12:46 - 18 Feb 2011    Post subject: Reply with quote
Deffo overheating. I had exactly the same thing happen on an old Toshiba a few years ago. Clean out the heatsink and fans as they will definitely have a wad of dust all over them. If it's still failing, get yourself a usb powered 'laptop cooler' from fleabay for a few quid.
'10 Skyjet SJ125-23 - Crashed Sad > '09 YBR 125 > '53 Suzuki SV650 - Died Sad > 2010 Suzuki VanVan 125 > '87 Yamaha FZ750 Sold > VTR 1000 FireStorm - Sold > Honda CB1000R
Scotsman37
PostPosted: 15:36 - 18 Feb 2011    Post subject: Reply with quote
I concur use a can compressed air through the vents to blast out the build up dust that has been sucked in over a long period of time....!
Use short blasts from the can while the laptop is switched off because it's extremely cold air that you woud be blowing across it!
CaNsA
PostPosted: 15:55 - 18 Feb 2011    Post subject: Reply with quote
Be careful when using the air......
All you could do is force the "fluff mouzzy" back into the laptop and possibly clog the fan stopping it completely. Seen and smelt it happen.
As previously mentioned, you will need to access the heatsink from the "in" side of it and remove the fluff that is covering it.
panrider_uk
PostPosted: 17:19 - 18 Feb 2011    Post subject: Reply with quote
That'll be it.
Mark
CaNsA
PostPosted: 17:22 - 18 Feb 2011    Post subject: Reply with quote
You need to follow the airflow path through the fan and find the heatsink mate.
dont stick anything through the fan to try and clean out the fluff you will only kill it Very Happy
panrider_uk
PostPosted: 17:25 - 18 Feb 2011    Post subject: Reply with quote
You could use a paintbrush to help dislodge the crap.
Mark
The last post was made 15 years, 216 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.56 - MySQL Queries: 13 - Page Size: 67.9 Kb
