Throttle sticking..
UKRedwing
PostPosted: 19:47 - 19 Feb 2011    Post subject: Throttle sticking.. Reply with quote
Hey guys,
I was fiddling with the bike today, fitted new air filter and had the carbs partially off and I think I've messed something up somehow.
It feels like the throttle is sticking but can't see why this would be the case as it was fine before, its so bad that I can essentially cruise control without holding the throttle in place.
Did I tighten the throttle cable up or something like this accidentally, doesnt seem to be returning fully at its own accord (I have to twist the throttle back off)
Just wondered if anyone had any other ideas for when I have a look 2moro.
Thanks
HD
PostPosted: 19:52 - 19 Feb 2011    Post subject: Reply with quote
Just take it off and put it back on. My personal thoughts are you may have twisted the cable as if it were straight and you pushed it back the cable would just flex.
But Im probably wrong Laughing
dextersaurus
Oil your throttle cables, see if that helps any Thumbs Up
Just get some WD40 or anything like that with the wee red tube that comes with it, and spray it down the sleeve of the cable, pulling it up and down to move the oil about... should help the throttle stop sticking.
Dunc
fiery tupp
PostPosted: 19:58 - 19 Feb 2011    Post subject: Reply with quote
If it has bar ends, the right one might be tight against the throttle grip?
If you can't fix it with a hammer , use your head .
UKRedwing
PostPosted: 14:39 - 20 Feb 2011    Post subject: Reply with quote
Thanks for suggestions,
Grip doesn't overlap bar end so it wasn't that,
sprayed wd-40 down the cable now mr dunk.
Was expecting cable to be too tight but where the cable goes into the throttle housing the adjuster nut thing was pretty slack. Tightened it up and the adjuster at the other end of the cable by carbs.
Yet to go out and test it properly but throttle seems to be returning a lot better. Very Happy
dextersaurus
PostPosted: 14:44 - 20 Feb 2011    Post subject: Reply with quote
That was going to be my next suggestion. when my throttle cable started to stick i tightnened it up and that seemed to sort it out Thumbs Up
Dunc
The last post was made 15 years, 133 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1.23 - MySQL Queries: 13 - Page Size: 47.24 Kb
