fitting new exhaust to my scooter help required
stevekingchef
PostPosted: 22:53 - 19 Feb 2011    Post subject: fitting new exhaust to my scooter help required Reply with quote
Hi guys
I have fit a new exhaust to my scooter a 1999 Yamaha yp250 majesty and was wondering if there is anything major I need to do or use when doing the job.thought I would ask before I start the job.
Hopefully should be straight forward
Any tips more than welcome
Steve
Livefast123
PostPosted: 23:14 - 19 Feb 2011    Post subject: Reply with quote
Best tip I can give you is to spray all the nuts and bolts involved with penetrating spray the night before, especially the manifold bolts Thumbs Up
Have you got a new exhaust gasket, it's best practice to fit a new one and you'll be kicking yourself if you don't and it leaks Sick
Make sure you have proper tools that fit well and have an extension bar for reaching the manifold nuts.
Current ride - Yamaha MT-07
stevekingchef
PostPosted: 00:43 - 20 Feb 2011    Post subject: Reply with quote
Cheers for reply I don't have a new gasket I will try grab one from Yamaha dealer I ordered exhaust online it giannelli brand I hope it fits ok the Yamaha one was nearly 500 quid that mire than the bike.
When u say penertrating spray I.e wd40?
Cheers again this thing seem more complcated that my tt600
steve
Paddy Blake
PostPosted: 08:31 - 20 Feb 2011    Post subject: Reply with quote
You might want to put some copper grease on the exhaust studs before putting the nuts back on.
It makes it easier to get the nuts off the next time.
Livefast123
PostPosted: 17:32 - 20 Feb 2011    Post subject: Reply with quote
Something like GT85 although you could use WD as a last resort.
You may need to rejet the carb if it's a performance exhaust but be guided by what the manufacturer suggests.
neil.
PostPosted: 20:39 - 20 Feb 2011    Post subject: Reply with quote
Get proper penetrating spray. 3-in-1 or Plusgas. I have used 3-in-1 penetrating spray with success. During the week before I took my old exhaust off, after the commute to work in the evening I sprayed some on the header screws (YBR doesn't have nuts/studs) - the hot downpipe/engine helps the penetrant get in. I'd then spray more on before bed so it could soak in overnight. I did this every night for 4 or 5 days. You can go one stage further and make up plastacine wells around the fastners and fill them with penetrating spray to immerse them in it.
I used A2 grade stainless steel replacement screws because the old mild steel ones had rusted heavily (I was praying they'd come out in one piece). Plenty of copper grease around them as well as I have been told stainless reacts with the aluminium cylinder head and could seize with it, but a rusty mild steel fasnter snapping (or head rounding out) when trying to undo it is also bad IMO. Also give the new gasket a coating of copper grease to create a better seal.
stevekingchef
PostPosted: 00:28 - 21 Feb 2011    Post subject: Reply with quote
Cheers again guy hopefully delivered tomorrow and hopefully gasket will be scalable at local dealer.will buy copper freeze and some spray too
Wish me luck
Steve
The last post was made 15 years, 136 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.15 - MySQL Queries: 13 - Page Size: 51.81 Kb
