GPZ500s Piston Rings
dextersaurus
PostPosted: 22:42 - 21 Feb 2011    Post subject: GPZ500s Piston Rings Reply with quote
Anyone got any idea where i can get a set?
Bike's burning oil at a fair rate so i'm rebuilding the engine next week, i've got a cam chain and getting a gasket set, so just need to get the piston rings replaced and i'm happy, but i can't seem to find them anywhere.
Someone's got to know where i can find them Laughing
Dunc
PostPosted: 23:00 - 21 Feb 2011    Post subject: Reply with quote
Sure it's not just the valve stem oil seals?
dextersaurus
PostPosted: 23:10 - 21 Feb 2011    Post subject: Reply with quote
Well i'm replacing the head gasket, might as well do the rings and cam chain while i'm at it.
How would i go about changing these/investigating?
Dunc
0l0dom0l0
PostPosted: 23:14 - 21 Feb 2011    Post subject: Reply with quote
Do a compression test?
I think if I remember rightly, if you do a baseline compression test and get say 110PSI, then put some oil down the barrels and the compression increases to say 120PSI, then its the rings that are fooked. Ie, iff the compression increases after putting oil down the barrels the ring are shot.
If it doesn't change, then its the valves.
PostPosted: 23:16 - 21 Feb 2011    Post subject: Reply with quote
Dunc
They'll be in the gasket set anyway. You'll need a valve spring compressor.
PostPosted: 09:52 - 22 Feb 2011    Post subject: Reply with quote
If you are doing a full strip then replace the primary drive chain as well. No tensioner on that so it can slap around a bit.
The last post was made 14 years, 336 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.46 - MySQL Queries: 13 - Page Size: 53.59 Kb
