KTM Dzus fastener alternative
Blue_SV650S
PostPosted: 19:19 - 22 Feb 2011    Post subject: KTM Dzus fastener alternative Reply with quote
One of my airbox Dzus fasteners went AWOL ... according to the local shop they are £15.06 EACH to replace!! Shocked
They did suggest an alternative mind you ... it is a 'Screw for plastic 6/30' (part # 0017060303) which are 68p for TWO!! - much better!! Very Happy
I know boundy needs one and there might be others of you with the same problem - but with a less clued up KTM dealer!! Thumbs Up
Klause
PostPosted: 19:25 - 22 Feb 2011    Post subject: Reply with quote
But wont the screw just fuck the Dzus female clip up?
Current bikes: 1960 Triumph 5ta x2, TTR600RE, KTM200EXC, Cagiva Elephant 900ie.
drzsta
PostPosted: 19:28 - 22 Feb 2011    Post subject: Reply with quote
you can get Dzus clips alot cheaper on the Net than that!!!
Blue_SV650S
PostPosted: 19:34 - 22 Feb 2011    Post subject: Reply with quote
No, I think it is the same 'pitch' is the same as the Dzus ...
It certainly screed in without any fuss ...
PostPosted: 19:36 - 22 Feb 2011    Post subject: Reply with quote
Yep, bought packs of 8 for a hell of a lot less than that years ago.
Quick google finds these
https://www.replicastuk.com/best_detail.asp?prod_id=8204
Klause
PostPosted: 20:33 - 22 Feb 2011    Post subject: Reply with quote
To be fair, those track fairing ones aren't always the right length. My ttr600 has them for the airbox. Standard ones aren't long enough, i cut and welded one longer. Yamaha wanted £28.
I still don't think a screw is good for it, the dzus doesn't exactly have a pitch, more of a slotted groove.
Blue_SV650S
PostPosted: 20:40 - 22 Feb 2011    Post subject: Reply with quote
Its a long Dzus, not the standard ones.
At the end of the day it does the trick and at the end of the day, the female bit of the Dzus is only a bit of bent metal ... I can't see it coming to any proper harm ..
Klause
PostPosted: 21:05 - 22 Feb 2011    Post subject: Reply with quote
I had the same problem with the ttr, i just found some old dzus fastners in the workshop and cut and shut it to the right length, at least it's still quick release Very Happy
Blue_SV650S
PostPosted: 21:09 - 22 Feb 2011    Post subject: Reply with quote
These ones are longer than thinner than the standard ones, so a cut-and-shunt probably won't cut the mustard here ...
Seriously, this is not a 'proper' bodge, it is a KTM recommended (and actual KTM) part! Razz
The last post was made 15 years, 248 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.14 - MySQL Queries: 13 - Page Size: 61.81 Kb
