How to service a GSXR 750
polarman
PostPosted: 17:05 - 23 Feb 2011    Post subject: How to service a GSXR 750 Reply with quote
I would like to service my bike myself but I'm not 100% confident.
Is there an idiots guide?
What tools do I need please?
Gixer 750
PostPosted: 17:19 - 23 Feb 2011    Post subject: Reply with quote
Some information would help, Year, mileage etc.
TBH I don't think it is a great idea to start buggering about with your bike I'm sure many will disagree.
The best way is to find a mate who is good at this stuff, and get them to do it while you help, you will bike up far more information than reading from any guide.
Haynes manuals are somewhat useless but are rarely 100% accurate and can cause more harm than good.
Minimum tools,
1/4 rachet and socket set, (4-12mm)
1/2 rachet and socket set, (10-22mm + the size of your rear axle)
Allen keys (2-10mm) Get ball ended ones if you want to make your life easier.
A mallet, pliers and or grips, WD40, Copper slip, brake cleaner.
Everything else get as and when you need it.
polarman
PostPosted: 17:28 - 23 Feb 2011    Post subject: Reply with quote
Cheers for the great post chris-red.
2006 model and has 8700mls. Due a service as its almost 12mths since I bought it.
How about just changing the oil, oil filter, air filter and plugs?
Gixer 750
Scotsman37
PostPosted: 17:36 - 23 Feb 2011    Post subject: Reply with quote
Check the following;
Lights all work as they should.
Brakes inspected for badly worn pads and inspect for corrosion on brake pods
Tyres have the required tread depth with no bold spots
Inspect drive chain and adjust accordingly to tighten to recommended tension, as noted in the manual for bike.
Check entire exhaust system for leaks!
Replace air filter as recommened when to do so by manual and the same for engine oil along with oil filter and washer for the sump plug, if necessary.
Regrease the swing arm if necessary and head bearing, etc, if found movement is some what stiff!
Check the wheels while the bike is on a paddock stand and check for any free movement by trying twist it side to side will indicate if bearings needing replaced or not.
Avora
PostPosted: 17:38 - 23 Feb 2011    Post subject: Reply with quote
Plugs are as easy as pull the HT lead off and undo them, depending on how much clearance there is (I'm used to diddy 125 2 strokes) then you might need to take any fairings surrounding the engine off, and even the tank. Meanwhile you can get to the airbox. And then find your oil filter, wap that off providing theres a tray to catch the oil and then once its all out, clean the surface, change an O ring, if there is one, and do it all back up. Replace the oil, until its at the right level.
Jobs a good'n! Thumbs Up
Kawasaki AR125 B8 - Getting ready for a summer time soon!
polarman
PostPosted: 17:55 - 23 Feb 2011    Post subject: Reply with quote
Cheers guys.
I think the trickiest bit will be the fairing.
HG do a spark plug socket and oil filter removal tool (useful if the thing is tight)
Just need to check what I have with the list red gave
Smile
Gixer 750
Bendy
Mrs Sensible
PostPosted: 18:17 - 23 Feb 2011    Post subject: Reply with quote
Get yourself the relevant Haynes manual. It'll tell you everything you need to know.
polarman
PostPosted: 18:32 - 23 Feb 2011    Post subject: Reply with quote
Confused
Gixer 750
Bendy
Mrs Sensible
PostPosted: 18:46 - 23 Feb 2011    Post subject: Reply with quote
I've always found them to be a decent guide, you don't follow slavishly of course, you still use your brain. Smile
polarman
PostPosted: 18:51 - 23 Feb 2011    Post subject: Reply with quote
Now I'm stuffed Very Happy
Gixer 750
Scotsman37
PostPosted: 19:05 - 23 Feb 2011    Post subject: Reply with quote
How to change a wheel while on the move....!
https://goodwitchbadwitch.files.wordpress.com/2010/07/third-wheel-motorcycle.jpg
polarman
PostPosted: 19:10 - 23 Feb 2011    Post subject: Reply with quote
Is that our next purchase for the lads in Aghanistan?
Gixer 750
PostPosted: 19:15 - 23 Feb 2011    Post subject: Reply with quote
Completely different to a big bike, my RXS takes 10 seconds to do, my bigger bikes can take the best part of an hour, it is not always an easy job depending on the bike.
polarman
PostPosted: 19:17 - 23 Feb 2011    Post subject: Reply with quote
https://www.bookdepository.co.uk/book/9781844257904/Suzuki-GSX-R600-and-750-Service-and-Repair-Manual
£16.31
Gixer 750
PostPosted: 19:22 - 23 Feb 2011    Post subject: Reply with quote
polarman wrote:
Confused
Like the one that told me to do a bolt up to 110nm of torque, when it would have sheered the bolt?
Or the RXS one that told me my seat had a pivot and could be removed using the key? (it is held on by 2 bolts no pivot.)
Don't treat the Haynes manual as gospel.
Changing the airfilter plug and oil should be a gentle afternoons work, find somebody who knows what they are doing and follow them is the best way IMO.
PostPosted: 20:07 - 23 Feb 2011    Post subject: Reply with quote
This will be better than a Haynes
https://www.2shared.com/document/7HRYi_6X/Suzuki_GSX-R750_K6_Service_Man.html
polarman
PostPosted: 20:18 - 23 Feb 2011    Post subject: Reply with quote
Many thanks Chris
Richard
Gixer 750
The last post was made 14 years, 337 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.32 - MySQL Queries: 13 - Page Size: 95.05 Kb
