| polarman |
 polarman Nitrous Nuisance
| chris-red |
 Posted: 17:19 - 23 Feb 2011 Post subject: |
Some information would help, Year, mileage etc.
TBH I don't think it is a great idea to start buggering about with your bike I'm sure many will disagree.
The best way is to find a mate who is good at this stuff, and get them to do it while you help, you will bike up far more information than reading from any guide.
Haynes manuals are somewhat useless but are rarely 100% accurate and can cause more harm than good.
Minimum tools,
1/4 rachet and socket set, (4-12mm)
1/2 rachet and socket set, (10-22mm + the size of your rear axle)
Allen keys (2-10mm) Get ball ended ones if you want to make your life easier.
A mallet, pliers and or grips, WD40, Copper slip, brake cleaner.
Everything else get as and when you need it. ____________________ Well, you know what they say. If you want to save the world, you have to push a few old ladies down the stairs.
WANTED:- Fujinon (Fuji) M42 (Screw on) lenses, let me know if you have anything. |
| polarman |
| Scotsman37 |
 Scotsman37 World Chat Champion
| Avora |
 Avora Renault 5 Driver
 Posted: 17:38 - 23 Feb 2011 Post subject: |
Plugs are as easy as pull the HT lead off and undo them, depending on how much clearance there is (I'm used to diddy 125 2 strokes) then you might need to take any fairings surrounding the engine off, and even the tank. Meanwhile you can get to the airbox. And then find your oil filter, wap that off providing theres a tray to catch the oil and then once its all out, clean the surface, change an O ring, if there is one, and do it all back up. Replace the oil, until its at the right level.
Jobs a good'n!  ____________________ Kawasaki AR125 B8 - Getting ready for a summer time soon! |
| polarman |
 Posted: 17:55 - 23 Feb 2011 Post subject: |
Cheers guys.
I think the trickiest bit will be the fairing.
HG do a spark plug socket and oil filter removal tool (useful if the thing is tight)
Just need to check what I have with the list red gave
 ____________________ Gixer 750 |
| Bendy |
 Bendy Mrs Sensible
| polarman |
| Bendy |
 Bendy Mrs Sensible
 Posted: 18:46 - 23 Feb 2011 Post subject: |
I've always found them to be a decent guide, you don't follow slavishly of course, you still use your brain.  |
| polarman |
| Scotsman37 |
 Posted: 19:05 - 23 Feb 2011 Post subject: |
| polarman |
| chris-red |
 Posted: 19:15 - 23 Feb 2011 Post subject: |
| Avora wrote: | Plugs are as easy as pull the HT lead off and undo them, depending on how much clearance there is (I'm used to diddy 125 2 strokes) then you might need to take any fairings surrounding the engine off, and even the tank. Meanwhile you can get to the airbox. And then find your oil filter, wap that off providing theres a tray to catch the oil and then once its all out, clean the surface, change an O ring, if there is one, and do it all back up. Replace the oil, until its at the right level.
Jobs a good'n!  |
Completely different to a big bike, my RXS takes 10 seconds to do, my bigger bikes can take the best part of an hour, it is not always an easy job depending on the bike. ____________________ Well, you know what they say. If you want to save the world, you have to push a few old ladies down the stairs.
| polarman |
 Posted: 19:17 - 23 Feb 2011 Post subject: |
| chris-red |
| chris-red |
 Posted: 20:07 - 23 Feb 2011 Post subject: |
This will be better than a Haynes
https://www.2shared.com/document/7HRYi_6X/Suzuki_GSX-R750_K6_Service_Man.html ____________________ Well, you know what they say. If you want to save the world, you have to push a few old ladies down the stairs.
| polarman |
The last post was made 14 years, 344 days ago. Instead of replying here, would creating a new thread be more useful? |
