key prob
blahheed
PostPosted: 18:37 - 23 Feb 2011    Post subject: key prob Reply with quote
i am needing a key made up as the original is missing.
is there numbers on the ignition barrel?
can the local locksmith do a copy of this?
Scotsman37
PostPosted: 18:53 - 23 Feb 2011    Post subject: Reply with quote
Depends if that particular Locksmith will do it or not or you may have to find another one that will.
You need the code from the ignition barrel and he/she should be able to cut a new a key from that.
Otherwise your nearest bike dealership has to order a replacement which may take time to arrive.
all in all I would in both options take your ownership documents + vin no. with you just to reassure the locksmith/dealership that you're the owner and not a thief needing the bike to work!
cb1rocket
PostPosted: 18:56 - 23 Feb 2011    Post subject: Reply with quote
if you had known the original key numbers which are stamped on the key itself....not sure about the barrell as your find most locksmith won't touch key reversal cutting.
stirlinggaz
PostPosted: 12:32 - 24 Feb 2011    Post subject: Reply with quote
some ignition barrels dont have a code (seen this on some zadi units)
means you have to remove the barrel/switch & take it to any decent locksmith.
most bike shops will arrange to do it, at a cost of around £40 Shocked ,so just cut out the middle man & take/send to locksmith yourself.
done it umpteen times with old bikes bought without keys.
cheers,
GAZ
The last post was made 14 years, 342 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.06 - MySQL Queries: 13 - Page Size: 38.53 Kb
