| Rowey |
 Rowey World Chat Champion
 Posted: 15:00 - 25 Feb 2011 Post subject: Datatool System 21 keeps going off |
Hi all,
I'm having a problem with the alarm on my ZX6R (2006). I bought the bike a few days ago, for the first few days the bike was fine, then yesterday morning the alarm went off for no apparent reason.
Later in the day I installed an optimate 4 charger cable. I went out for a ride for a couple of hours and parked the bike up, not a peep. I then got home, gave the bike a wash and put her in the garage. A few hours later and the bike started going off for about 10-15 seconds. I ran out to find nothing wrong and rearmed the bike and went back in only for it to go off as I was walking to the house. This has been the case ever since.
If I arm the bike, the alarm goes off after about 5-10 seconds. The service mode code indicates it's the movement sensor. If I press the oval to disable it, the bike does not go off.
The bike was stored, apparently on a trickle charger for a long time before I bought it.
So far I've sprayed some WD-40 in a few connectors and the control box, changed the orientated of the box and replaced the fuse but none of this has helped.
Any one got anything else I can try?
Thanks in advance  ____________________ ZX6R C6F.
Never argue with an idiot. They'll only bring you down to their level, and beat you with experience. |
| chris-red |
| MarkJ |
 MarkJ World Chat Champion
| scott dt125 x |
 scott dt125 x Two Stroke Sniffer
 Posted: 15:45 - 25 Feb 2011 Post subject: Its |
most probly the battery they dont last long with alarms attached to them when the battery starts going flat they start beeping,and going off like you described try getting a new battery or charging it up.....Oh good luck  |
| Rowey |
| Rowey |
The last post was made 15 years ago. Instead of replying here, would creating a new thread be more useful? |
