Honda cb 125tdc
lewishuggins1...
PostPosted: 18:57 - 25 Feb 2011    Post subject: Honda cb 125tdc Reply with quote
poor bike died today.
does anybody have a complete head assembley.cant find one for love nore money.
also has anybody had or herd of a slight oil leak from the headgasket.the previous owner after i purchased the bike said i "did em up left to right as tight as i could"
YOU W####R EVER HERD OF A TORQUE WRENCH AND A HAYNES MANUAL
its distorted the head and is too far out to skim out in practicality.do you think a replacement head will solve the problem.
and would you advise to service the head de-coke it and valve stem seals.
chers for reading guys
PostPosted: 19:06 - 25 Feb 2011    Post subject: Reply with quote
How much is it distorted? Is that the only problem the head is suffering?
lewishuggins1...
PostPosted: 19:14 - 25 Feb 2011    Post subject: Reply with quote
can fit a 2mm feeler gauge between head and a straight edge. and also after further inspection a hairline crack from the left hand sparkplug hole.
think the heads scrap to be onest.if the crack was not there it may be saveable possibly.but may find a suitable replacement
PostPosted: 19:18 - 25 Feb 2011    Post subject: Reply with quote
You're right it's scrap. Don't sling it in the bin, because all the bits inside like cams and followers are expensive and hard to find.
lewishuggins1...
PostPosted: 19:24 - 25 Feb 2011    Post subject: Reply with quote
Thanks for your advice i will store the parts in the broken parts box.
Any ideas where to find a new head.Or anybody on here who will have such a sacred stash of ageing components.
PostPosted: 19:27 - 25 Feb 2011    Post subject: Reply with quote
I've asked the only person I think might have one. TDC heads are like hens teeth.
Frost
PostPosted: 19:32 - 25 Feb 2011    Post subject: Reply with quote
There was somebody on here asking about CB125's a week or so ago. we all warned him that the top ends weren't so great Laughing
De coke is no doubt a good idea, same goes for stem seals. You might have to get it skimmed regardless and hope for the best. Taking some measurements you could work out the compression ratio, and possibly fit a thicker gasket if it's too high.
PostPosted: 19:33 - 25 Feb 2011    Post subject: Reply with quote
What year bike is it?
Teflon-Mike
tl;dr
PostPosted: 19:54 - 25 Feb 2011    Post subject: Reply with quote
Between 82 & 86 if its a TD-C.
Heads are common with all the small bore twins.
CB125, CM125, CD125
CD185, CM125
CD200, CM200
CB250 'Nighawk', CM250 'Rebel' (actually 233cc, NOT the 248cc 'Big-Block' twin)
Most of the 'other' variants use 360deg cranks so if you got one you would HAVE to use teh CBcam-shaft out of your engine, otherwise, straight swap.
BUT check condition of cam-journals before you buy, ALL these engines suffer oil starvation problems that sees the camshaft eat the head. Hence if the motor's been scrapped, THAT is often the reason!
Frost
PostPosted: 20:00 - 25 Feb 2011    Post subject: Reply with quote
Mine had oil starvation that lead to loss of compression on the left hand cylinder. It was a quick bike before that, 75 even 80 with a hill assist, after it drank more oil than i expected and staved it a bit it was 70 MAX that was indicated to so probably more like 65.
Would a 250 engine fit in mike? Wink
PostPosted: 20:02 - 25 Feb 2011    Post subject: Reply with quote
Mike my brother had a CB125T and a TDC and it was a long time ago now but I'm sure the T cam would not go into the TDC head. Some feature on the cam that didn't line up.
lewishuggins1...
PostPosted: 20:03 - 25 Feb 2011    Post subject: Reply with quote
Its a 1982 model.May have to get it skimmed and hope for the best.
if anybody knows of one hanging about tho.this will be a tempoary fix
PostPosted: 20:05 - 25 Feb 2011    Post subject: Reply with quote
Lewis look at this ebay auction, in the text he says he has a running engine:
https://cgi.ebay.co.uk/HONDA-CB125TDC-IGNITION-COIL-CB125-TWIN-CB-125-TDC-/280627712251
lewishuggins1...
PostPosted: 20:10 - 25 Feb 2011    Post subject: Reply with quote
YOUR A STAR!!!!! just messaged him and not a million miles from here.
fingers crossed thanks guys.
does anybody know a good company to use to rebore a set of barrels.the bikes dont 22 thousand miles would it be worth getting them done and treat her to a new set of pistons while the head is off ?
PostPosted: 20:16 - 25 Feb 2011    Post subject: Reply with quote
My mate thinks he might have one. He's going to check tomorrow.
The last post was made 14 years, 361 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.91 - MySQL Queries: 13 - Page Size: 86.94 Kb
