how to fit rollers and belt on 2stroke dna 50cc
dna50
PostPosted: 01:44 - 26 Feb 2011    Post subject: how to fit rollers and belt on 2stroke dna 50cc Reply with quote
how do i fit rollers and belt on my dna 50cc its got a slight screech coming from there when i accelerate its there and garage has told me they need doing. how would i change them both providing i have ordinary tools and no variator puller etc and how long would it take me?
and also is it safe to drive the screech is very slight when i take off its fine after thatt?
hsaeed
connornrg
PostPosted: 02:08 - 26 Feb 2011    Post subject: Reply with quote
very easy, buy the rollers, they MUST be the correct weight, you can weigh them if you are unsure, also buy the belt, preferably a kevlar belt.
open the side case, lock the variator with a screwdriver and then unbolt it. pull the whole assembly off careful to remember what order you disassembled it all in. replace rollers. replace belt reassemble. jobs a goodun
Bikes (Not Bikes Really Just Shitty Mopeds)
**04 - Piaggio NRG MC3**02 - Yamaha Aerox 50/100**07 - Piaggio NRG Power - Shit.**
dna50
PostPosted: 02:26 - 26 Feb 2011    Post subject: Reply with quote
okay cheers i have a standard exhaustt but someones put an unlimited cdi on it i want to improve the acceleration will i have to buy the standard roller weights bbecoz i have the standard exhaust or what? and would i have to greese the rollers up before i put them on?
hsaeed
lukamon
PostPosted: 04:06 - 26 Feb 2011    Post subject: Reply with quote
Ok, this i double yourself but easier with two.
First, take all the bolts out of the belt cover and full it off. There's a basket sealing it but should be reusable. You'll see both belt pulleys, and a small gear may fall out from just behind the front one, this is the starter motor gear, put it back how it cameout.
Getting the variator off is best and easiest with a locking tool that bolts to.the case. Search Google for Dan 50 variation lock tool or something. The alternative is a big blade long handled screwdriver jammed.in and held by someone else. Make sure you pull the variation off from the vary back not bit by bit or it falls to pieces.
Get an oe belt and rollers. Don't be tempted by cheap stuff or kevlar belts. I know from experience that they Will break or at very least wear out quicker.
Oe rollers are better because they are made mostly of a metal band wrapped in tough plastic. Cheap one are soft plastic, when.i bought an exhaust that came with some they wore flat in about 2 weeks severely robbing the bike of power and acceleration.
I beliiivvve the rollers you want are 7.1g
killa wrote: Im an ass man myself
dna50
PostPosted: 15:09 - 26 Feb 2011    Post subject: Reply with quote
ok thanks ill buy genuine rollers and belt, would i have to greese up the rollers? and how long would the whole job take roughly?
hsaeed
lukamon
PostPosted: 16:16 - 26 Feb 2011    Post subject: Reply with quote
no dont grease the rollers, first off plastic doesnt need to be greased and second, that thing spins @ 10,000 rpm, grease is NOT gonna stay in there itll go everywhere.
my spelling in last posty is awful, sorry Embarassed
anyway, if itll wait a couple days for it to arrive, order this:
https://www.gileraspares.co.uk/sparesGilera/partImage.asp?GPN=VS18368
and it should take about half an hour if youve done it before, a couple hours if you havnt, its fairly simple really.
make sure you do the nut up tight and be VERY careful not to cross - thread it. couple mates didnt do it up, and beive me they make a nastry noise if the nut comes off while youre moving Laughing
dna50
PostPosted: 17:39 - 26 Feb 2011    Post subject: Reply with quote
ok thanks a lot would it be safe for ride with the slight screech that comes when u take off for about another month i only do short 3 mile journeys daily?
hsaeed
cb1rocket
PostPosted: 21:26 - 26 Feb 2011    Post subject: Reply with quote
should do but expect to break down sooner or later. There won't be any damaged - just a kanckered belt and rollers.
Check your brake pads aren't sticking either
dna50
PostPosted: 00:29 - 27 Feb 2011    Post subject: Reply with quote
its had new pads front and back and i took both calipers off the bike and rode it aswell!! and it was still there and its coming from near the side casing so it must be the belt and rollers. okay
hsaeed
The last post was made 15 years, 82 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 2 - MySQL Queries: 13 - Page Size: 61.88 Kb
