Noob piston question about nsr 125
nsr_J22_FOXEYE
PostPosted: 10:48 - 26 Feb 2011    Post subject: Noob piston question about nsr 125 Reply with quote
Here I found a 65mm piston for my nsr where as its 55mm standard, I am curious if I were to buy this
https://cgi.ebay.co.uk/HONDA-NSR125-MALOSSI-BIG-BORE-65MM-PISTON-KIT-GASKETS-/300530618454?pt=UK_Motorcycle_Parts&hash=item45f9055056
What other parts do I need? and I am asuming i need to bore the barrel out?
Could someone be so kind as to tell me the method and other parts I will need please?
Never Ride Faster Than Your Angel Can Fly
Avora
PostPosted: 11:35 - 26 Feb 2011    Post subject: Reply with quote
For a basic fit it and ride off, all you'll have to do is send the barrel for a rebore, possibly a replate. Depends what the barrel has already, if it nikosil plated already, then its going to cost more. But if not, then id suggest it. Have a look at Stan Stephenson's website, or ring a 2stroke tuner up and ask. It'll cost you £100 minimum for the rebore I should imagine. Not Worth it in my opinion. But then again, its your bike.
Kawasaki AR125 B8 - Getting ready for a summer time soon!
nsr_J22_FOXEYE
PostPosted: 12:29 - 26 Feb 2011    Post subject: Reply with quote
why would you say not worth it? Had the bike for a year and will be due a rebuild soon, and im keeping her for another year after i pass my test Smile , is it then worth it? Thank you for your reply
Avora
PostPosted: 12:38 - 26 Feb 2011    Post subject: Reply with quote
As far as I can foresee for me it would just convert to ball ache, like the extra cost when you need to rebuild it more often. And thats a hell of an increase in piston size. I'd do some thorough research into others that run NSR's with that size piston, and any troubles they have had, or what the increase was like. Generally an untouched and loved 2 smoke will only need rings changing until mega miles . But i'd get on the phone and find out how much its all going to cost before you decide on anything. If its your main transport then leave well alone, and use as many genuine parts as you can afford.
As a project though, do it! Very Happy
EDIT: The NSR has too weak of a crank to do this reliably. However the piston alone is worth £80. Plus you have to account for the costs of setting up the bike and so on and so on. If you want power buy a bigger bike.
PostPosted: 13:31 - 26 Feb 2011    Post subject: Reply with quote
Very much doubt you could just bore the stock barrel out by 11mm from 54mm to 65mm. Likely that the head gasket mating surface would be too thin and possible the walls of the barrel would be too thin. If you did then you would likely affect the port timing as well (as the tops of the ports are angled).
PostPosted: 17:53 - 26 Feb 2011    Post subject: Reply with quote
That..
and are you on a CBT? im sure a big bore makes its over 125cc, not just the bhp limit but physical engine capacity.
cb1rocket
PostPosted: 22:28 - 26 Feb 2011    Post subject: Reply with quote
thats can't be in anyway suitable as its for the standard 150cc NSRs as from calculating the bore of the pistion and stroke gives a 180cc!
No way is that suitable for the 125 engine.
Best bet would be to get the 150 european kit
The last post was made 15 years, 83 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.22 - MySQL Queries: 13 - Page Size: 52.64 Kb
