vfr750 startermotor noise not engaging.
Cognitive_Faux
PostPosted: 12:38 - 15 Feb 2011    Post subject: vfr750 startermotor noise not engaging. Reply with quote
morning
ok i have a 1995
honda vfr750
for the last three years i always noticed a slight mechanical 'granchy' noice when the startermotor engaged... just before it started.
however. this weekend.. what ever it was has decided to break
when you hit the start button, soound of something like to gears just catching eacother but stopping then being left with the sound of an electric motor spinning mindlessly.
has anyone come acros this before?
if its anything like the statermotors on my jeeps, the spring on the gear has given up....
so im hoping i can have the motor mech replaced.
any help, suggestions would be helpful
thanks guys. and girls.
bike theory (pass) bike test (pass)(4 minors) car theory (pass) car test (pass)(1 minor!!!)
cb125t->sr125->expressII50->xlr125->GS550L & GS550E->XBR500 'chop'->YZF600R->FZS600->GSF650->fantic 212cc->gsf650->kwak GT750->VFR750 ->
HGV class 2 (pass)
Odie
PostPosted: 15:22 - 15 Feb 2011    Post subject: Reply with quote
Sounds like the starter clutch is gone tits up, parts of the rotor on the side of the engine, 3 rollers grip the crank, have been known to get flat spots and then the wont grip, they are available via "dave silver spares" probably.
PostPosted: 16:06 - 15 Feb 2011    Post subject: Reply with quote
What Odie said. Or possibly a broken spring under one of the rollers. They usually go intermittant before failing altogether.
It's under the clutch cover. Not a big job to do. Once the oil's drained and the cover is off, jam a bit of stout cloth (folded over bit or denim or similar) into the gears to lock the starter clutch and clutch gears so you can undo the centre nut without it all turning.
You sometimes find bumping it slightly backwards in gear turn things enough for it to catch next time.
Cognitive_Faux
PostPosted: 00:39 - 28 Feb 2011    Post subject: Reply with quote
thanks guys.
didnt solve the problem as it remedied itself before i could.
bumped it backwards abit...
since then... its erm.. well been better than it has been in three years.
hondas.. mind of their own!
thanks again. last i know it is when it finally goes.. and i will know what to do.
HGV class 2 (pass)
Cognitive_Faux
PostPosted: 12:17 - 28 Feb 2011    Post subject: Reply with quote
Vincent wrote:
Waiting for something to go "Bang" before investigating is not always the best course of action, or the cheapest Wink
your right.
i will get in there and have a look at weekend.
waiting things go bang.. i do that alot with my off roaders.
HGV class 2 (pass)
The last post was made 15 years, 113 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.67 - MySQL Queries: 13 - Page Size: 50.88 Kb
